S80 Head Bolts
I do realize that the last post was in '08 but I'm hoping for a quick response. I am in the same situation, I have a 99 s80 t6, and my mechanic ( not familiar with volvos) is having an issue re assembling top portion of the engine, ( valve/cam cover) . He asked me to look for info on the bolts. Are there special bolts needed to secure the cover, said something like they seem to be too short/ if he tightens them he feels they will strip. Can you email me the pdf file you mentioned in the above posts, they sound like what he needs
midwestautopro
- Year and Model: 04 S80
Hi \, my name is Alvin and i have an 04 S80 with a 2.9 L turbo and i'm also replacing the head gasket and the timing belt with the water pump, idler pulley and all the stuff thats in there before i put it bac together. Can you please send me the pdf file i need to do those 2 jobs and tell me what special tools ill need to complete the 2 jobs and where to get them? Please and thank you
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
You'll need a cam lock tool to lock the cams at the rear/transmission end of the motor. Don't confuse this with a tool that locks the sprockets. Other than that you don't need any other special tools that I can recall. Don't forget to order turbo flange gaskets and soforth if they are not part of your kit already.
If you are handy with computers you can acquire VIDA which is volvo's software, it contains the procedure and specs for these jobs.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
LagunaPete
- Year and Model: 1999
I am an ASE MAT. I'm about to retire actually. (my back is killing me at 54 yo) Regarding head bolts on a 2.9 liter Volvo Non-Turbo:
If you do not use new "stretch bolts", you are asking for some definite follow up maintenance after only about 20 hours running time. You will need to re-torque the 14 head bolts over again unless they are new, "stretch" bolts. Seasoned bolts lack this elasticity and will result in a very high likelihood of a re-occurrence of breach in the cylinder head gasket.
In my opinion, these bolts should be replaced every time the cylinder head is re affixed to the block.
Quite frankly,in consideration of the labor involved with this repair; I believe it would be a careless irresponsible action to perform this repair without replacing the cylinder head fasteners.
Thank You.
Thank You.
whowhatwhywoof
- Year and Model: 1999 s80 t6
Hello all....I need your assistance I'm going to be removing the head on my s80.. I am a decent mechanic but if there is a PDF file that I could utilize to assist me in the breaking down of it please could you please send it to me thank you so much
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
Here you are:
Some of the files are named in Bulgarian, so i guess you'll rename them as you figure out what they contains.
There is almost everything you need to know doing this job. Make sure you take a look at this threat: '99 S80 T6 Top End Rebuild Pics - read it from end-to-end it wont take you so much time, but you may find some useful info to safe you a lot headache
GOOD LUCK
GOOD LUCK
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
- 1330 Views
Last post by Nevada1906
- 614 Views
Last post by JDS60R
- 15 Replies
- 2938 Views
Last post by 1ezliving4ume
- 1013 Views
Last post by rspi
- 1385 Views
Last post by erikv11
