Head bolts loose
beoutside
Year and Model: 1999 xc v70 awd
Post by beoutside »
At 50000 miles after a head rebuild I had 4 bolts lossen enough to cause a head gasket leak , was running great, make sure your block has very clean or chased threads as in traceyssoaps tutorial but I would change the oil lube to red permatex. That is a tip from a 40 year veteran mechanic. It acts as a lube and will prevent bolts from coming loose but not work like thread tight. I had followed all the instructions and double checked my torque settings. We have a volvo XC 1999 V70 and I had the head redone professionally at a machine shop at 170000 due to a sticky hydraulic valve causing a burnt/blown hole in a Exhaust valve.
The symptoms were intermittent coolant loss and finally stumble starts then fine as it warmed up. Looking at the head gasket there are no compromises to see but we're it should be clean around the cylinders it has carbon deposits corresponding to the " loose" bolts. Hope this helps other Maintence OCD types like us who expect 400000 from their volvo.
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines :)
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Thanks for that info. Nothing i would have expected. Life is full if surprises, ain't it?
1996 855 R,
2010 V70 D5,
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have done several heads with oil on the bolts, some with over 40,000 miles with no issues yet.
Have you pulled the head and verified that bolts are loose? These heads have some issues with cracks between the valve guides.
