Junkyard or www.erievovo.com or www.vandsautodismantlers.com for the harness. Automotive crimp connectors (covered with heatshrink or electrical tape) to make the splices.Familytruckster wrote:I'm trying to complete this repair and have hit a bump. I lost the entire driver side turn signal lens, bulb socket and electrical wiring connectors (just 3 bare wires hanging). I have the light lens and bulb/socket replacement parts but have been unable to find the 3 wire female pigtail or connector that attaches to 3 prong male bulb socket. How do I complete this repair? What parts do I need (local volvo parts dealers say the part is not available)? If I need to splice the wires what are my options?
S80 Cornering Light Lens and/or Bulb Replacement 1999-2001
Front Corner Volvo Lens / Bulb Replacement
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Familytruckster
- Year and Model: S80, 2000
Thanks to Sam in parts @ Volvo of Dallas! He helped identify the correct parts needed for this repair. You need 3 repair terminal wires, Part #30656689. The 3 terminal wires fit into what Volvo calls a 'Insulator', part #978139 (aka: plastic connector piece that the 3 prong terminal wires fit into). When all 3 terminals are pushed into the insulator/connector it fits perfectly into the Lamp Socket, Part #9178546 (aka: plastic turn signal bulb connector that goes into the plastic cover assembly). Cut the termianl wires to fit and use a butt/crimp connector (as highlighted by Vegas) to splice the the new wires to the old. Note: The green wire goes in the middle. I had to use trial and error for the black and white wires on the sides. Missed on the first try but it worked on the 2nd.
- 1717 Views
Last post by RickHaleParker
- 3868 Views
Last post by remermn
- 1174 Views
- 1397 Views
Last post by Skymongrel
- 4173 Views
Last post by silentcircuit
