Have you gone through the suggestions given-
Visual inspection for leaking oil, for instance?
disapearing oil 1997 850 base
- Has thanked: 17 times
- Been thanked: 35 times
I took a 760T from 300km per liter to 2000km per liter oil, in a short amount of time, simply by using an oil for high mileage engines. The consumption was still declining when we sold the car. Leaky valve seals will only take a little oil.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
Another vote for high mileage oil.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
coolfische
- Year and Model:
so, verdict is in.... no leaks, pcv system is fine....car is just burning it up. so if it goes through 2.5 quarts per 1000 miles do i keep and just fill it with oil, or ditch it and find something else. Does anyone know I don't fix it but keep the car am I looking at even bigger problems down the road, exhaust ect.?
coolfische
- Year and Model:
I will try the higher mileage oil and see what happens.
thanks
thanks
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
You might get some spark plug fouling and catalytic converter problems.coolfische wrote:so, verdict is in.... no leaks, pcv system is fine....car is just burning it up. so if it goes through 2.5 quarts per 1000 miles do i keep and just fill it with oil, or ditch it and find something else. Does anyone know I don't fix it but keep the car am I looking at even bigger problems down the road, exhaust ect.?
In addition to the high mileage oil, you could add a can of STP. It sometimes helps.
Also you can try auto-rx, available at http://auto-rx.com
- 2156 Views
Last post by SonicAdventure
- 17 Replies
- 4907 Views
- 1026 Views
Last post by xHeart
- 494 Views
Last post by misha
- 1090 Views
Last post by beigg
