Important Information on Ecu issues (850,S70 series)
meteg
- Year and Model: 2007 V70 2.0T
the diagonal metal strap is something we dont have in the european volvo models.I guess its only available in U.S market models. my car is a european version and has no metal strap on it.
note: the ecu's need no reprogramming after removal.. the only matter is you have to switch the ignition off and wait least 10 mins until all the power to the control modules are cut. and then remove the modules from the box.otherwise damage to the ecu modules is possible.
Please. There must be somebody out there that can help me. I've already broken part of the support for the windshield fluid fill tube. Now in trying to force the metal strap off, I can see it slight crack just starting at the bottom of the box by the strap. I could really use someone insight and knowledge on how they opened their's.
JRL
- Year and Model: Several
- Been thanked: 16 times
I have swapped ECU's and it's an in and out deal even with the battery connected, no issues
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I have european model and i have that metal strap on top of ecu box.meteg wrote:the diagonal metal strap is something we dont have in the european volvo models.I guess its only available in U.S market models. my car is a european version and has no metal strap
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bobsnow100
- Year and Model:
You can get a big spray can of Electrical contact cleaner at Home Depot in the Electrical Department.
yeah i have a can, i wonder if the ECU is to blame for my issues, since replacing the starter I can turn the engine over but it never will start. Checked for spark and am not getting any. Changed plugs ,wires,cap,rotor and still no spark. I got a TPS code so I replaced that, replaced camshaft position switch, and ignition coil and still no spark HELP !!
- 1393 Views
Last post by MadeInJapan
- 1664 Views
Last post by Ozark Lee
- 950 Views
Last post by oragex
- 56 Replies
- 14424 Views
Last post by JeffHicks
- 2356 Views
