'95 850 Cruise Control points of failure?
Volvo Cruise Control Fixes - 850, S70, V70 Points of Failure?
My cruise has not worked at all since last summer but as it was failing it would hold for a while and then disengage. Does this behaviour provide any clues as to whether is would be the brake switch, vacuum lines or the controller?
- Has thanked: 17 times
- Been thanked: 35 times
Yes, that's how our old 850's cruise control died- it was the vacuum hose attached to the cruise pump under the battery tray.
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
I've talked to a couple Volvo guys and they said the elbow in the vacuum line under the tray always drys out and cracks.
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
Delboy3867
- Year and Model:
Same issue on '96 850. Cruise was working, started to act erratically, then stopped completely. Did without it for weeks then, on a whim, pulled up on the brake pedal, heard a small click, and it's worked fine since. From what I read, the brake switch seems to account for about half or more of cruise issues and it's cheap to try it out before getting hands dirty.
crisleggett
- Year and Model:
My cruise control has been acting up and then tonight it stopped while in use. The cruise light went off and I was unable to switch it on again. I immediately thought it was a fuse. When you refer to the brake switch what exactly are you talking about?
The brake switch is actually slightly above the brake pedal under the knee cover on the driver's side. The way the pedal arm is, when you push down on the brake pedal, it pushes in a plunger for the brake light switch....this in turn turns off the cruise control. Check to see that this plunger/switch is aligned correctly. If it's not, you could be driving around with the brake light on and cruise control disabled all the time.
marginal
- Year and Model: V70 D5 2003
- Has thanked: 1 time
I wonder what could be the problem with mine.
The symptoms are as follows:
1. When I activate it it takes about 1-2 seconds to start (which I believe is too long).
2. It does not control the speed evenly, often slowing down and then accelerating again.
3. Just a very light touch on the break pedal stops it (I'm not sure this is not OK though).
Could this be a leak in the vacuum system?
BTW I checked the the vacuum hose attached to the cruise pump under the battery tray, and it is OK.
Thanks for the help.
Sounds like a leak...check it carefully...all the way to the ends.
Unfortunately the diagram in VADIS doesn't show the entire hose system, only what's up at the cruise control motor itself
That said, you might find information in the downloadable manual on the 850. I'm adding the section on the cruise control here:
- 1080 Views
Last post by theiceman69
- 17 Replies
- 6479 Views
Last post by ignatz
- 1358 Views
- 807 Views
Last post by oragex
- 11 Replies
- 14652 Views
