Find a different website:
http://www.fcpgroton.com/product-exec/p ... +Seats+Kit
Squeaky Strut Mount
Sladethesleeper
- Year and Model: 1998 S70T5
1998 S70T5 - 210k miles
1998 V70GLT -110k miles
2004 Chevy Silverado 1500 Z71 - 305k miles
1965 Mustang Convertible
I like miles...
I like miles...
Yes, #5 in the swedishautoparts picture is the spring seat and #7 is the strut mount. The strut mount is basically a bearing and the top of the spring seat fits up into it.
The FCP Groton page above shows an aftermarket parts set. Lots of people have advised against getting aftermarket, especially ScanTech. FCPG also sells the OEM parts; this is the OEM spring seat. http://www.fcpgroton.com/product-exec/p ... ory_id/185
I don't know the answer for sure as to whether the 2003 XC90 spring seat fits (I think it does), but Ozark Lee can probably answer.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- Year and Model: Many Volvos
- Been thanked: 76 times
Any year XC-90 (OEM) will fit and work fine on the 850 / 70 series cars.
If you buy anything that says aftermarket you are playing with fire unless you just enjoy replacing the parts.
It is your choice.
It is your choice.
Sladethesleeper
Sorry, didn't pay attention to the one I posted...definitely go with OEM.
Not sure on real labor. It took me about 3 hours on the first side with a really cheesy spring compressor, and about 1 hour on the other side.
I like miles...
I like miles...
Hello,
We have a 1998 Volvo S70 T5. The front left side has all of the signs of needing the spring seat replaced. When you push on the front left side it is very squeaky, and when driving and making turns you hear the same, however when driving straight you don't hear it. My question is how difficult is this job? And if just my front left is squeaky can I just replace those or should I do both sides? Also I read you might as well replace the strut mount while your there, is that necessary?
And lastly, do the XC90 spring seat part for sure work for the '98 S70? Why wouldn't you just get the part for the '98? I thank you very much for your help, am really hoping this is something I will be able to do!
Thanks!
Joe
Thanks!
Joe
Welcome to MVS,
There are a bunch of things that can squeak in the suspension - Spring seats, strut mounts, struts, control arm bushings, and sway bar bushings all come to mind.
The real test on the spring seat is to grab the big inverted castle washer on the top of the strut and try to twist it, you can even use a wrench but don't get carried away.
The top of the strut shouldn't turn easily and it should turn more than a few degrees either way. If it does turn easily then the spring seat is indeed shot.
I think all Volvo sells now through the parts department are the XC90 spring seats, the aftermarket guys may still have a distinction but it is a distinction without a difference since anything but OEM or IPD Heavy Duty seats are going to crap out again quickly anyway.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I brought in my own parts and was charged $50.00 a side but they were also doing my timing belt etc. Strut has to come out and be compressed to swap in the new parts. 50~75 each, let them do it.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Where did you spray - from above - or ? (I have just noticed mine is squeaking - and tried spraying with silicone spray from above - but not able to hit any sweet-spotsPeterG wrote: 15 Feb 2019, 16:30 I just sprayed silicone lubricant on it and the noise went away. For two weeks so far I have no squeaky noise.
But I consider this as temporary solution.
- 957 Views
Last post by GreenMagicMan
- 934 Views
Last post by erikv11
- 1005 Views
Last post by amblerman
- 3190 Views
Last post by patcal
- 1053 Views
Last post by oragex
