XC90 Radio quit working
FREEBUSINESSES
- Year and Model: 2005 XC90
- Been thanked: 3 times
Pulled out AMP, dry as a bone as I regularly check the drain tubes in sunroof and cowl drains, so no corrosion at all.
FREEBUSINESSES
UPDATE: I pulled out rear located AM/FM tuner module, and when disconnected, both AM/FM and now CD is not working, so given this, does anyone know which MOST connection is in line, does the connection go to radio head first, then to rear AM/FM tuner and then last to the AMP? The reason I ask is that when I pulled fuse to AMP, the CD still operated fine, kind of strange since you would think AMP fuse would pull down CD from working, unless it does not go through AMP which makes no sense, but then again, Volvo's never make any sense, at least not common sense. lol
Having the same is here on a 04 XC90 I literally just bought. Last night when I test drove it was working great. Today after purchase it doesn’t even turn on? The guy I bought it from days it has a mind of its own and will work for awhile and then doesn’t. Nothing on the screen comes on. All HVAC stuff below works - following thread to see if I can find help
My radio turned off/blacked out. I disconnected one terminal at the battery, I pulled out and reinstall the fuses one by one from the side of dash at driver side and also the fuses at rear left quarter panel. Then I reconnected the battery terminal. The radio reset and powered up. Save my self $180.00 that the dealer was asking for diagnostic cost.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
My wife's 2004 VOLVO XC90 T6 has issues with cd player not working. When you first start up ignition the cd player sounds like it's searching for a disc but never finds a disc. Her AM/FM radio still works. Anyway after reading this thread it sounds like the head units have a bunch of issues on these earlier model XC90 's.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
deejay
- Year and Model: 2003 xc/90
- Has thanked: 3 times
I am going to give the battery and fuse deal. I did the battery reset but did not do the fuses. I know the rear block does have some dust to her. I tried looking at the trunk line from pass seat to under the shift console and the seat belt wires. Still no radio and intermittent CD.
411 to follow.
411 to follow.
- 1633 Views
Last post by BEJinFbk
- 1563 Views
Last post by GGs98S70
- 6472 Views
Last post by 93Regina
- 1287 Views
Last post by nelaco
- 4144 Views
Last post by 850TurboTurtle
