2001 V70 T5 Tailgate
melobsterman
- Year and Model:
most likely a wire. my 01 did the exact same thing.
MelangeX3
- Year and Model: 06 XC70, 01 V70 2.4n
It's Probably one the Relays in the rear control panel in the cargo area. Usually behind side access panel. The lock servo occasionally goes bad too. This is located in the tailgate next to the lock assembly. Using your hand, gently bang on the metal near the release handle and alternate pushing the lock/unlock repeatedly, it will eventually unlock. If this happens, don't lock the car again! I got it unlocked and a Dealer Valet kindly locked my car while waiting for service. AAAAAaaaaggghhhh!
I have replaced mine 3 times so far, since 2 car accidents have jolted the car and caused later malfunctions. If you buy a replacement 15amp plug in relay, you can swap them out one by one til you find the culprit. Dealer charged me $200 in electrical diagnostics to do this exact thing. Found the panel by accident while looking for a way to unlock the frozen lock servo on the fuel door. That one, I just disconnected the plug and removed the lock mechanism. No problems after 2 years. Good luck!
Thanks, MelangeX3. Right now my tailgate is OK, i.e. it locks and unlocks. I have checked the wires at the hinge for breaks but they all look OK. The next time it doesn't work I'll follow your advise and check the relays.
Hi Johnny. Today , for the first time, my 2001 V70 tailgate did not open though the locks seemed to be working properly. I read a small bit somewhere about trim pushing against the tailgate and jamming the lock tongue too tightly against its receiver. So, acting on this hunch, I leaned into the taligate as I worked the remote and VOILA!! It opened immediately and seems ok now. I might make sure the meeting surfaces are not too rusty or add a touch of grease to hopefully reduce the likelihood of recurrance.JohnnyO wrote:My car is a 2001 V70 T5. My tailgate won't open using my remote or the unlock button on my door. Is there another way to open the tailgate except taking it to a dealer.
Thanks, Toronthab. My tailgate mechanism has been working intermittently. Some days it locks and unlocks then in other days it just won't unlock. For no apparent reason it will unlock after a day or two. Now it's been working for the last two weeks. Next time it won't unlock I'll try your suggestion.
Hi Johnny
I always get a lock response up or down, but the handle wouldn't budge. Neither could I unlock it from inside. Just leaning into it while using the remote seems to have freed the mechanism and it opened. Next time I tried to open and close, after pushing the carpet back a bit, it was no problem. Coincidence possibly, but I'm a bigger fan of Aristotle and Aquinas than David Hume!
Cheers and good luck.
- 2699 Views
- 2801 Views
- 766 Views
Last post by 98v70dad
- 2741 Views
Last post by pierremcalpine
- 1006 Views
