P0172 code broken elbow
noyesno
Year and Model: 1997 850 t5
Post by noyesno »
Thanks for the great post. I had the same code and didn't know of this particular elbow 'till I saw this thread. Just found mine was bad and after liberal application of foul language and curses to Volvo engineers, was able to effect the change. I would recommend using a needle nose about 12" or longer if you have one, to hold the insulated line while trying to remove and install the elbow. As well, if you happen to be changing out the alternator or p/s pump change this at the same time. When putting in the new one I found it best to put the nipple end on first and then, with the one hand, aligning the hose and elbow to mate them up.
Red-Arrow
Year and Model: 850 T5 1995
Been thanked: 2 times
Post by Red-Arrow »
I get a similar code of 232 and 315, I know 315 is idle control valve but I think I found the same problem with the vacuum hose from the turbo side. It was cracked and showed signs of perishing but I can't tell if its allowing non-metered air into the engine triggering the fault code 232. I thought 22mpg combined was ok for a T5, are you guys saying thats bad?
Life would be enjoyable if it wasn't so painful to live.
Goldy
Year and Model: 1998
Post by Goldy »
All my hoses are hooked up any other things to check ? 1998 S70 nonturbo Thanks
digitalnomad
Year and Model: 2003 & 2007 XC70
Post by digitalnomad »
My elbow looks fine, but I'm wondering about the other end. Can someone please describe or post a pic of where the other end of this hose connects?
1995 850 Turbo Wagon
A2 has trouble codes 231, 414
digitalnomad
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
It's the top most (meaning towards the top of the picture - connected to the valve with the fat hose) of the three hoses near the turbocharger here:
'98 S70 T5
2016 Chevy Cruze Premier
digitalnomad
Which number on this photo? Thanks for the help.
digitalnomad
jblackburn
3. Nice numbering, I'll haveta steal that for future reference :)
'98 S70 T5
staansS70
Year and Model: S70,1998
Post by staansS70 »
matthew1 wrote:Second one, part #9155862. You don't need to remove the coolant hose if you have the dexterity of an elf. Otherwise, it helps. I used a clamp on both ends because it repeatedly blew off one side or the other. :evil:
The attachment po172_elbow.jpg is no longer available
The attachment po172_elbow2.jpg is no longer available
New to this forum, but not new to forums in general. Sorry to rehash this thread but I desperately need some assistance with this issue.
When I remove my coolant hose the coolant comes flushing out. What should I be doing so that isn't happening?
Also per some IPD installation instructions* it says I should "pull off the fuel rail cover, disconnect all the injector connectors, and move the harness out of the way." Is this necessary? I can't tell from your pics if you've done this or not.
*See attached
TIA,
Staan
PI-318 VACUUM ELBOW INSTALL GUIDE.pdf
(129.58 KiB) Downloaded 401 times
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
Some coolant will come out, blame gravity. Don't do this when the car's hot/warm, obviously.
No, you don't have to remove the fuel rail, spark plugs etc. But that would make it much easier.
Also -> Amazon link
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
I would drain the coolant first, 2 quarts or more. If clean, save it, and use it for refill.
