I have the amp in the void area behind heater core in my car now. It sounds much better and I am no audiophile so it had to be noticeable for me to pick up on it. I'm a country music fan and beer drinkin', cheatin', huntin', luvin', and divorcin' all sound so much more real.
I found it in a car at pick-n-pull.
Does an S70 OEM radio amplifier exist?
nicopag
- Year and Model: v70 2.5T, 1999
In my V70 I have 8 speakers, one per door, 2 in the dash corners and 2 in the read door Pillars.
I have a SC900 and I dont have the center speaker in the dash.
If I buy the prologic accesorie, I will have better sound? or its wasting money?
Thanks
Thanks
V70 2.5T, L.H.D /S.R, 1999
JRL
- Year and Model: Several
- Been thanked: 16 times
There is no
"Pro Logic AccessorY"
What are you referring to?
If you install a Dolby processor without the center speaker, your gains are so minimal it's not worth it, (I know, I did it in anticipation of the rest of the system which I'm doing this week).
The only way to get better sound is to find a dash with a hole in it, (used Dolby dash) buy a center speaker, (then make up the center speaker harness as it's not available anymore) and then upgrade the rest of the speakers
nicopag
Ok, I mean the Dolby processor.JRL wrote:There is no
How can I get the wire color of the two speakers that are in the rear pillar?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
That is indeed the 4 x 50w amp that ships with the SC-900/901 decks.nicopag wrote:I think this black box is the amp. Its below the passenger seat.
As JRL states, you can just plug and play the Dolby surround unit,
but without the center channel, it's not very useful. It'll just make
your stereo sound hollow and boomy. The center speaker is the key!
Typically if you install the dolby pro logic processor, you cannot have a amplifier behind your radio, because this processor takes its space, and therefore you would have the amplifier under your seat (as the SC-900 and SC-901 do not have a built in amplifier). I upgraded my system to a SC-901 with a dolby processor (got it all off a junkyard C70 for cheap) and bought a whole charcoal dash with the center speaker attached. I've already had a 4 channel aftermarket amp to drive all the speakers in the car at the time. All I have to say is what a difference (dolby pro logic mode)! It moves the sound stage upfront and gives a more realistic feel. This unfortuantely creates a mono effects channel in the rear speakers which I cannot imagine would be great sounding for rear passengers. The original Dolby ProLogic is a rear mono effects channel. The "3CH" mode is what I use when I have rear passengers (keeps a stereo sound going to the rear, but no prologic).
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
- 1154 Views
Last post by BEJinFbk
- 1802 Views
Last post by RickHaleParker
- 1551 Views
Last post by TWC
- 2234 Views
Last post by theWIFES_S70
- 1258 Views
Last post by Rattnalle
