jablackburn wrote:I believe that's where it does go.
I would start with just a compression check for now, if you've got the tools for it. You should see 180-200 psi on a used 2.4 engine. Try it when cold, try it with some oil in each cylinder to rule out rings, and maybe try it again when warm to see if my theory stands up. Once you do it the first time, it's very quick to go about it again. You'll want to pull all of the plugs out, then crank the engine over 5-6 times with the throttle wide open, and take the best number you get for each cylinder.
It's almost certain something's letting oil into the coolant if you've got it floating around again, so leak down might not be very useful.
Thanks, I will probably get that done Monday as the other mechanics have the compression tool I need. As far as water/oil mix, there is a slim possibility that there was some left over water in the oil from before as I tried to flush it all out, but may not have gotten it all. I was originally planning to change the oil and filter again after a few hours of running with fresh oil/filter to get any residual moisture/water out, but then this all happened. I will hopefully have some answers or results Monday night. Thanks again.
