Evap P0446 problem
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Hmm, where did you find that rollover valve? My evap leak came back too after I replaced the purge valve.
polskamafia mjl
May as well ad this link for future members who find this thread looking for answers:
-> http://volvospeed.com/vs_forum/index.ph ... ode-p0455/
yojaywuzup
- Year and Model: 850 1997
I went to pull this line off and realized it is a two piece hose ( meaning it has a hard tube on the inside and a rubber tube on the outside which is what is cracked. Could this still be my issue or am I not looking in the right spot?
yojaywuzup
I've finally had a chance to revisit this problem and keep seeing references to the evap vent valve circuit. Is the vent valve the one inside the drivers side fender? I followed the shop manual procedure and even put voltage on the pruge valve to test it and it works. I am getting 6 volts at the purge valve, but am not sure if that is wht it should be seeing. Any advice would be greatly appreciated.
Thanks again,
Jay
Thanks again,
Jay
- 11 Replies
- 2085 Views
Last post by marcus
- 1826 Views
Last post by BrianV70
- 16 Replies
- 1018 Views
Last post by Brickbox8398
- 575 Views
Last post by Raul_duke
- 735 Views
Last post by Ozark Lee
