Ticking is driving me crazy (no pun intended)
JDS60R
Been thanked: 3 times
Post by JDS60R »
Ask them to check for piston slap when the head is off. Also for rod bearing and wrist pin noise. The upper bearing cap on the big end of the rod gets beaten up when someone does a Seafoam treatment with slightly too much liquid.
Eventually Seafoam will sell its product in an actual foam format so the inexperienced will no longer run into these issues.
Retired
crh
Year and Model: 1998 XC70
Location: Vermont- back to Santa Cruz/Felton, CA in mid-August!!!
Post by crh »
JDS60R wrote:Ask them to check for piston slap when the head is off. Also for rod bearing and wrist pin noise. The upper bearing cap on the big end of the rod gets beaten up when someone does a Seafoam treatment with slightly too much liquid.
I stand corrected. The only thing that they did was the Lucas treatment; it was performed as, coincidentally, what JRL has outlined on these forums a few times; the procedure for this, when we discussed what was being done the other day, sounded familiar for that reason... I *just* now looked again at the list of things they did (it was all comped except for the lifter job P&L), and although I THOUGHT they did the SF, they didn't... everything else they DID do as per my outline. Sorry.
Are you saying that a well-done SF treatment is worth the effort at this point, with another head going on perhaps tomorrow? It sounds like even a perfectly-executed SF treatment can possibly expose some of the internal of this motor to unwanted effects either immediately or down the road... would you do an SF treatment on this motor with competent and experienced mechanic doing the honors? I'll ask them to check these components you outlined in any case... it can't hurt, eh? :)
JDS60R
Post by JDS60R »
No - they will clean the piston tops when the head is off- no reason to do it.
No -not true. A well done SeaFoam treatment yields the positive results the product is known for.
Right- have them check the bottom end and piston slap while the head is off. This is done by rocking the pistons to find slap and turning the crank back and forth by way of the crank pulley while holding the piston down with a finger to find excessive play in the rod bearing or wrist pin.
There is also no need to take the head off to due this. I place multiple microphones on the block in different areas and record it on my computer from a cold start. This way I can compare the sounds (volume/pitch and rate) and locate the knock. Its a 1 hour job.
Retired
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
dude add another quart of oil, when u start the car the oil isnt reaching the lifters. it happens to many volvos in the morning that's just piston slap, I am telling u add some more oil so your dipstick is full! Anyways this fixed it for me.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I used to have a pretty clicky top-end. New camshafts and I'm assuming cleaning sludge buildup, etc out of the passages in the head and it runs EXTREMELY quiet now - no valve noise at all.
Actually what I would do is an ATF flush - through the engine.
Drain the oil. Fill the motor with 5.5 qts of ATF and let it run for 20-30 minutes. DO NOT DRIVE OR REV THE ENGINE OR YOU COULD DAMAGE THE BEARINGS, but it can idle just fine with no damage. Shut it off and repeat if you want. Then fill it with a good detergent oil (Mobil1 is my favorite). This will pretty much alleviate any oil pressure issues by cleaning all the crud out of the engine - ATF has lots of detergents in it. It's a tried and true old-school mechanics trick.
Piston slap is generally a much deeper noise and less ticky. I've never heard it on a Volvo engine - only the top ends are usually noisy.
4.0 Jeeps and 3.1 and 3.4 liter V6 and lots of V8 GM engines are widely known for this.
Vs starved lifter noise
'98 S70 T5
2016 Chevy Cruze Premier
Volvo4251
Year and Model: 98 S90
Post by Volvo4251 »
The old '98 V70 I had used to tick like crazy from time to time, it was always worse in the winter time. So during the winter months, 10W-40 was put in. The mechanics suggested a thicker viscosity not only for the winter season, but for the ticking as well. It definitely helped, although it still would tick from time to time. It's just one of those things that happens on a 5 cyl. Volvo... and moreover older 5 cyl. Volvo's as well.
Drive Safely.
2007 Volvo XC70 Adventure Series
1998 Volvo S90
Previous Volvos:
96 Volvo 850 Platinum
11 Volvo C30 T5
07 Volvo XC90 3.2 AWD
98 Volvo V70 2.5 SE
95 Volvo 850 Turbo
94 Volvo 850
91 Volvo 240 Wagon
90 Volvo 240
89 Volvo 740 GL
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Well, brilliant idea I have had the lifter noise for(probably forever) but more so in the winter. I'm going to try and run some ATF before I run new oil... How'd it work out for you? nothing at all now?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
