Switch Doctor advertises the S/V series switches as OEM (Many people list things as OEM so I am always skeptical).
I found the for real OEM switch for less money at www.Tascaparts.com (around $104.00).
1998 v70 Power Windows will not work
How To Check For Leaking Fuel Injector
- Year and Model: Many Volvos
- Been thanked: 76 times
Volvo S/C70 Master Power Window Switch 1998-2000 can be purchased from the SwitchDoctor (https://www.switchdoctor.net) with a lifetime guarantee for $25.00
- Has thanked: 2211 times
I have had a Switch Doctor master switch still in the box. I bought one but when it arrived it was really plasticy compared to the OE part. I found a good OE switch and fitted it instead and the SD one is still in the box 8 years later.
- Has thanked: 1611 times
- Been thanked: 4075 times
Switch doctor has absolutely the most schizophrenic reviews of any vendor I’ve ever seen
abscate wrote: 21 May 2021, 04:20 Switch doctor has absolutely the most schizophrenic reviews of any vendor I’ve ever seen
…and a year later I am a customer. For $25 vs $160 new, I’m in.
Fit and finish are excellent, electrical connections perfect, function perfect
Will report on longevity.
Since I have 6 1999s, I bought two.
Installed on the T5, five minutes. Popped old one out with a scout knife. Original replaced in 2008?
Happy Spring!
- C1ph3r
- Year and Model: 1999 V70T5
- Has thanked: 32 times
- Been thanked: 7 times
Hey Abscate, just stumbled across this post. i just replaced mine with switchdoctor also. i did the swap on april 27th. in about a week after the install (of which i probably only used my windows like 3 times maybe) the driver window switch stopped working. it would start working again after i turned off the car and back on again. i emailed switchdoctor support on may 2nd and had a replacement in the car by May 7th! Their warranty support was fantastic! at least that is my experience. i wish they had a switch for the other 3 doors.abscate wrote: 13 May 2022, 02:29abscate wrote: 21 May 2021, 04:20 Switch doctor has absolutely the most schizophrenic reviews of any vendor I’ve ever seen
Happy Spring!
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
Those other three doors are junkyard specials. I’ve got a ton of them. They never break due to low duty cyvle
- C1ph3r
Yeah I can see that. But the switchdoctor ones function so nice. Nice smooth, light clicksabscate wrote: 14 May 2022, 01:59 Those other three doors are junkyard specials. I’ve got a ton of them. They never break due to low duty cyvle
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
They have clearly improved their product over the years as those look nothing like the one I bought all those years ago. I just replaced an aftermarket one in my friends car a couple of days ago. About a year old I'm told. It was still working but the driver's door switch had come loose.
Update, first unit failed 14dats after install. I’ll chase warranty this week. Using my second one in meantime
Here is some info for driver door switch bypassing. Putting +-12 volts across A3 and A4 on the driver door switch plug will operate the window up/down if the switch goes out. This won’t fix a jammed window or bad motor of course.
- 772 Views
Last post by Scoot329
- 532 Views
Last post by heman0118
- 935 Views
Last post by precopster
- 669 Views
Last post by jmfunnyfarm
- 1337 Views
Last post by StupidS80
