Dim Headlights 2000 Volvo S70
Allen in Hemet
- Year and Model: 2000 V70XC SE
OSRM owns Sylvania. I too put a pair of the silverstars in my car. It did make an improvement. Not as big of improvement as it did on my wifes '01 civic. Some day, I may just spend the big money and get the clear lens lights from an '04 C70, then those sylverstars will shine.
If you don't care about a "white-ish" look to the headlights, Philips X-treme Power are one of the brightest Halogen bulbs currently available in the market.
I have these in my 855 and Subaru Impreza, bright bulbs but the light is yellow.
Wagon Brigade >> 94 855 NA | 97 Subaru Impreza OBS | 07 Suzuki SX4
Previous Bricks >> 90 240 GLE 2.0 | 98 S70 T5A 2.0 | 03 XC90 T6 2.9
Beemer John
- Year and Model: V70 XC 1998
Jacquie-
I just bought a '98 V70, and last night I drove it for the first time after dark. Holy Dimbulb! I would do better sitting on the hood with a Zippo. I snooped around the net last night and learned of a few possibilities for the cause of this dangerous situation. One that I haven't seen mentioned in the other responses here is corroded ground wires from the headlights. I don't know where on the car they are, or even if I can fix them, but I will find mine today. Another recommendation was to pick up a pair of Euro-spec headlamp lenses. They are, apparently, much better at getting the light out onto the road ahead. (Thanks a lot, US DOT!)
Btw, I've tried the Sylvania/Osram superwhite bulbs before on other vehicles. While way whiter than the stock bulbs, they never lasted more than a few months. I stopped using because of that. Your mileage may vary.
Good luck and be super-safe after dark in the meantime. These are scary lights.
JB
JB
JB
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
before you invest in lenses be sure the root cause is not the reflective coating on the reflectors no longer being reflective (I love this sentence).
- dono
- Year and Model: 04 V70&XC70 2.5T AWD
- Has thanked: 43 times
- Been thanked: 6 times
2004 V70 AWD t2.5 wagon
I also have very dim lights lately. Had a battery at the end of its life so I replaced and lights still dim. I measure 11.69 volts at both low beam plugs. Is this close enough to the 12v or do I have a volt supply problem?
I checked the charging system with measurements at the battery - I measured 12.4v engine off; 14.2v running at idle and 13.5v under load (lights, high beams, radio, AC on hi).
thanks
thanks
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi
1999 Mercedes e320 4Matic 238k mi
2008 Toyota Avalon XL 165k mi (meh)
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Isn't this almost always the case? Especially at 19 years old for some of us...jimmy57 wrote: 10 Nov 2012, 06:34 before you invest in lenses be sure the root cause is not the reflective coating on the reflectors no longer being reflective (I love this sentence).
Pricing some new headlights. Seems like the cheapest, new, headlights can be had for about $150 shipped via eBay.
https://www.ebay.com/itm/Halogen-Headli ... 2~&vxp=mtr
I love the sentence, Jimmy. But I think we can find a way to fit more words that reflect the warmth and attentiveness of the MVS community!
Retired:
2015 Volvo S60, T5, 85K
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I went the crystal route and was very pleased.theWIFES_S70 wrote: 07 Apr 2018, 15:36
https://www.ebay.com/itm/Fits-2003-2004 ... f1&vxp=mtr
- wizechatmgr
You have some sort of supply problem - those should be at the ~13.5V you see at the battery. Either a bad wire, relay, or ground issue.dono wrote: 07 Apr 2018, 14:18 2004 V70 AWD t2.5 wagon
thanks
- theWIFES_S70
Thanks, was wondering what sort of options we had. So do the 03-04 C70 lights fit into the P80s? Or is that strictly a 'bastards' thing?wizechatmgr wrote: 07 Apr 2018, 17:13 I went the crystal route and was very pleased.
Retired:
- wizechatmgr
It fits on the bastards. If the bastards fit yours then it should fit. I'll wait for someone sure to give a definite answer. The last thing you want to do is pull the trigger on something that won't fit...
- 517 Views
Last post by dj_v70
- 3271 Views
Last post by mecheng
- 14 Replies
- 2890 Views
Last post by Stu70
- 1497 Views
- 3433 Views
Last post by ShadowDancer
