Cooling Fan Relay Easy Replacement w/pics
Has thanked: 2207 times
Been thanked: 1852 times
Look closely at the 2 connectors. The one in your picture closet to #1 has a raised notch on the connector that lines up with the slot in the relay. #2 does not. #2 if I recall plugs in down the side of the back of the radiator.
Bigbishop
Year and Model: 2003 S60 2.5T
Has thanked: 2 times
Post by Bigbishop »
@scot850 Thank you so much for pointing that out 😊
Bigbishop
Post by Bigbishop »
@abscate thank you, will wait patiently. I am trying to figure out a non running fan. I directly powered the fan from battery and it turned. Then I individually grounded the pins in the middle port of relay that are associated with the yellow and yellow/white wires and the fan turned at different speeds depending on which pin I grounded. Does this mean fan and relay are good?
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Bigbishop wrote: 26 Dec 2024, 08:23 @abscate thank you, will wait patiently. I am trying to figure out a non returning fan. I directly powered the fan from battery and it turned. Then I individually grounded the pins in the middle port of relay that are associated with the yellow and yellow/white wires and the fan turned at different speeds depending on which pin I grounded. Does this mean fan and relay are good?
I'm with Dr. Abscate, those moldex plugs only go into one port on the relay, look carefully at the pin location and the nubs on the plug.
And yes, if the fan powers up with direct wiring, that is diagnostic.
Bigbishop
Post by Bigbishop »
@abscate Thank you for the information. At what temperature does cooling fan kick in? I observed temperature on a scan tool go up to 103 degrees but fan did not kick in. Should I have observed for longer?
Has thanked: 1610 times
Been thanked: 4071 times
Often not until 105 C. I documented this once sitting in a line for US Canada border
The fan is also controlled by the coolant temperature sensor. Check it is operating normally, then also check the wiring at the connector mounted near the back of the power steering pump. This corrodes with age and wires become brittle as does the connector.
Bigbishop
Post by Bigbishop »
@abscate Thank you so much for this new perspective of 105 C
Bigbishop
Post by Bigbishop »
@scot850 Thank you for this, will have a look at the variables you have introduced.
Bigbishop
Post by Bigbishop »
@abscate Oh my oh my! So going by your advice, I waited past 103 C and at 105 C I heard that sweet sound of fan kicking in. Thank you so much. Seemed I worried too early 😊 Thanks to @scot850 and @foggydogg too for helping out.
