xc90 Fuel rail pressure sensor mount
This topic is in the MVS Volvo Repair Database » P80 1999 2000 POWER STEERING HOSE NOTES
xallenx
Post by xallenx »
Boston Volvo or call Erie VOVO to see if they got one off a wrecked xc90.
95 850 NA 279K on 1st motor (78K on the 2nd)
06 xc90 FW 2.5T 86K+
mjhott
Year and Model: 1997 850, 2005 XC90
Post by mjhott »
I'm looking to change out my FRPS this weekend too on a 2005 v8 but it looks like you have to remove the inlet manifold to get access. the1stkim, did you remove the sensor with the inlet plenum in place? basically, how the heck did you get the darn thing out??? Any help from anyone would be great. I'm normally really glad to have the v8 model but not for this job! Thanks a million!!
volvodoc
Year and Model: 01s60
Post by volvodoc »
yes you in fact broke the fuel rail try erie volvo.com for a used rail
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The top portion of intake is easy to remove and gets you access. There are coolant hoses to the throttle that will need to be removed as the throttle is on this part of intake. Hold the fitting the FPS goes into when removing the FPS so the fitting the hose goes on doesn't get stressed. Lube the o ring on the new FPS before you install.
paz5050
Year and Model: 2006 XC90 4.4L V8
Has thanked: 2 times
Post by paz5050 »
for anyone that happens to see this thread circa 2022:
https://www.swedespeed.com/threads/volv ... st-7977052
