Compression test results, trusty Harbor Freight junk gauge:
192-194-192-172-202
200-210-190-180-205
So #4 is down a little, I am going to be optimistic and consider the rings are just extra sticky/dirty in that on. I'll check again in 500 miles or so, see where the readings are.
I like the advice of just running dino oil for now, so no additives have gone into the case yet.
Crankcase cleaning - just started up a junkyard engine
- Has thanked: 312 times
- Been thanked: 818 times
I watched the how to video on SeaFoam's website. It looks like that for general cleaning use its safer to just add it to the oil and add some to the gas tank. My question from before was really about getting a suggestion for which vacuum hose would be best to use on a Volvo for that application.erikv11 wrote:Proceed at your own risk, many people love this treatment but there are a very few reports of it supposedly ruining the engine. If you are going to do it, read some of the many many posts about it, don't just go on my recollection.
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
Seafoam into the crankcase (oil) is common too, that is what I was asking opinions on in my original post, but in the crankcase it will not touch the intake ports or the valves. For the intake treatment, just use any vacuum hose (or a new one you put on just for the treatment) from the tree.
brandonbeach14
- Year and Model: 2.4T V70, 2001
Seafoam also makes a spray now that you can put into the vacuum tree with less risk of vapor lock.
SimLyons
- Year and Model: 2001 V70 T5
I used all 3 methods. In the crankcase (changed oil after about 40 miles), in the gas and in the intake (via the tree, using a hose from my cllection and about half a can of Sea-foam). My car runs really good, no more black junk out the exhaust all over the garage floor and smoother running. Of course, I did all this just prior to changing out the PCV. It was all part of some major servicing I did. BTW: The car was using about 1 qt of oil/800 miles before. Now it has used none measurable in 1100 miles.
Sim
- 33 Replies
- 3267 Views
- 16 Replies
- 3562 Views
Last post by pred
- 1884 Views
Last post by chestermo
- 26 Replies
- 1924 Views
Last post by Blacklab467
- 4081 Views
