93 850glt
robt
Year and Model: 850glt 1993
Re: 93 850glt
Post by robt »
misha wrote:We MUST know if fuel pump is running before the car dies.
My advice is to ask somebody to listen for it's "noise" in the trunk or beside right rear wheel.
When we are sure that fuel pumps is ok,then we can go further.
fuel pump is still running when engine stalls
another thing it does is when i try to restart, it turns over normally then hesitates then turns over but wont start doing it several times while turning key
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Next thing you need to check is fuel pressure at fuel rail.
Sounds like fuel pressure is low.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
robt
Post by robt »
misha wrote:Next thing you need to check is fuel pressure at fuel rail.
ok,will try that and let u know,thanks for your help
robt
Post by robt »
hi, checked fuel pressure reg, vac line was bad, fixed it now it is ok, i'm hoping that is all it was
misha
Post by misha »
Well done!
Now...enjoy the ride!:wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
robt
Post by robt »
misha wrote:Well done!
joy was short lived, still stalling once temp gets to normal. when running prior to warming up i can rev engine without a problem,every thing is normal
misha
Post by misha »
I would check fuel pump relay.It can make troubles when it become hot.
Still no check engine light?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
robt
Post by robt »
misha wrote:I would check fuel pump relay.It can make troubles when it become hot.
ok,will try relay, no check engine light
misha
Post by misha »
The only thing that bothers me is that check engine light is not on.It means that there is no problem with sensors,but sounds like its a failing Maf(because it stalls when the engine reach operating temperature).
You must know that even if check engine light is not on,there could be pending codes stored in engine ecu(port A2) & ignition ecu(port A6).I would check those ports again,just to be sure that there are not pending codes stored in ecu's.
There could be a few more things to check....if pending codes are not stored.
How's your battery voltage?Do you have problems like slow cranking when it sits overnight,dimmed headlights?Is alternator voltage in specs(13.5-14.4v)?
There is a "how to" jump a fuel pump relay on the forum somewhere.Try with "search" or simply pm Ozark Lee or Jblackburn for help.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
