HU-615 to aftermarket Head Unit
HU-615 to aftermarket Head Unit: Volvo V40
Above is the factory head unit that came as part of the premium sound system. Like you said, the adapter I used will not work for your car. You could install a head unit using the parts I listed, but it won't sound very good, and doesn't solve the adapter issue. I had no idea there were different versions of the HU-615. Pretty interesting.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
I'm sorry - I was unclear. There is only one version of the HU-615 head unit. The whole overall installed system is different.
I don't recall the exact specific items but its like this (this is a montage of different years so some specifics may be different)
Basic system : HU-6xx 8 speakers
Performance system: HU-6xx 8 speakers + 200w amp + subwoofer
Premium system: HU-8xx 11 speakers + 300w amp + subwoofer + center channel w/ surround sound
I think the Premium only included the HU-8xx series because it needed the center channel output. If you have the HU-6xx and a subwoofer and amp then you might have the performance system not the premium.
Again, this is sort of fragmented info based on my three different systems so it might be a little different on your year/model
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
The picture Qhoove posted shows only an 8 pin adapter and is labeled 615. The picture I posted shows 6 and 8 pin adapters and is an HU-615. It seems like there might be different versions. Unless, Qhoove, do you have something other than the 615? That's one thing that has never been addressed in this thread.
fazool
I re looked at the OP picture and the label does say 615.
I think maybe that pic above is a 650 - it looks like mine and as I recall, the 615 might not support the external amp, but I dont recall.
Hey guys, the head unit is definitely an HU-615, I'm mainly trying to install this headunit so I can install a subwoofer, so I had already planned on installing an external amp, with the adapters (besides Autoleads PC9-414 Wiring Harness Adapter) could I still install the new head unit, or will I still need a DIN adapter?
fazool
Again, I am doing this from memory.....and a montage of my experience with my HU-650 and my HU-615 and my other-year S40, so I might be a little foggy on my details.
OK,l so the HU-615 has two DIN connectors. One is a 6-pin and thats for the pre-amp outputs. The other is an 8-pin and thats for external MelBUS accesssories (CD changeer, satellite receiver).
If you want to feed pre-amp signals to an external amp, you need the 6-pin DIN connector. The pin-outs aer in the diagram below.
This head unit does not include the center channel or a sub channel output so you will need an external amplifier that can separate those channels. You probably want a 5-channel external amp or a 4-channel amp with pre-amp outputs to daisy chain a second sub amp.
- 03-RCA-Diagram.jpg (20.4 KiB) Viewed 2619 times
- 796 Views
Last post by leapdragon
- 1645 Views
Last post by Eddystone
- 2139 Views
- 709 Views
Last post by sk55
- 20 Replies
- 5022 Views
Last post by speedyt5
