2007 XC90 Taillights on a 2006 XC90?
Shadows
Year and Model: XC60 D5 '12
Post by Shadows »
007 wrote: Am I right?, I just watched on ebay and it seems the newer light has 5 bulbs, and the older (03-06) just 4, please confirm.
Thanks.
Correct, but it's not a problem. :D
To change the rear lights on my 2004 XC90 to the 2008 ones, I did as described here.
Fortunally, Had I saved the old ones, so I can make this little how-to-do :wink:
Remove the small triangle floor piece.
Pull the black tap, and remove the interiorpiece the covers the rear taillights.
Unscrew the two nuts, that holds the lamp.
Here is the new and the old one, side by side.
And from the back. And as noticed there is 5 bulbs on the new one, and 4 on the old.
But is only because the rear light uses 2 bulbs, instead of one. You can see the wiring with grey and white wires to these two.
So nothing to worry about.
The Wires that goes back the cars wiring is exactly the same.
The right one is from the old light and the left is the new.
And the two wirehousings that connects the cars wiring. Still the same. :D
This worked perfectly on my car. But I can't guarantee for others cars.
007
Year and Model: XC90 0406, 2012 C70
Post by 007 »
Thank you very much, appreciate your help!. Regards.
lasthumain
Year and Model: xc90 2005
Post by lasthumain »
you really did a good job. I'm wondering how you did install the LED light on the tail lights upper and lower?
lasthumain
It’s not plug and play you ll need to get the tail light harness too plus the fog light harness. cause the 07 has 2 small lights for the parking light instead of the 1 for 03-06. the deference is on the fog light harness the plugs are not the same and the cable are red and black before both of them are black. But i still curious about how the led was done.
Shadows
Post by Shadows »
lasthumain wrote:It’s not plug and play you ll need to get the tail light harness too plus the fog light harness. cause the 07 has 2 small lights for the parking light instead of the 1 for 03-06. the deference is on the fog light harness the plugs are not the same and the cable are red and black before both of them are black. But i still curious about how the led was done.
The wiring is delivered with the new lights, so it's not a problem.
007
Post by 007 »
Thanks.
Hello, it is necessary to replace both upper housings?, or can I install the new style lower housing with the old style upper ones?
Thanks.
Shadows
Post by Shadows »
Yes, you Can easally replace the lower part of the lamps, without changing the upper part.
007
Post by 007 »
Thanks my friend, now I am just wondering How to make the upper parts illuminated like gshadow325´s XC90...
Regards.
Shadows
Post by Shadows »
007 wrote:Thanks my friend, now I am just wondering How to make the upper parts illuminated like gshadow325´s XC90...
Regards.
My thoughts extactly :?:
