noisy lifter
SimLyons
- Year and Model: 2001 V70 T5
So familiar! When I got my 97 850R 9 years ago it had a very faint (steady) clicking. Nothing to concern me at the time. I and the previous owner used only Mobil 1 10-30 and OEM filters, Volvo or MANN (only MANN for past 5 years). Clicking got louder and finally took it to my indie for a look-see-hear. He and I agreed tappets. His solution was replace the full set. A $1,200 later (with some other work at the same time, still clicking. Now, after 5 years since replacing tappets and 9-10 years since first noticed still clicking away. Cold, warm, hot...all the same. I don't THINK it's enough to worry about right now, but it's on my list for next summer. Pull the oil pan and replace the sump pickup o-ring and well as any other seals/0'rings. If that doesn't do it (stop the clicking), I give up and drive it tll death do us part.
Sim
Mad Dog Tannen
- Year and Model: 1999 V70XC
Adjust valves? That's what I would look at on any car of mine:)
1999 V70XC, debadged, 3" exhaust from downpipe to tip, 16T, ARD tune, R manifold.
2000 Honda RC51 (toy)
- Year and Model: Many Volvos
- Been thanked: 76 times
They are not adjustable on the Volvo white block engines.Mad Dog Tannen wrote:Adjust valves? That's what I would look at on any car of mine
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I would say start with the O-rings at the oil pickup tube, BUT it just sounds like it's one lifter instead of all of them.
Does this engine get to see high RPM often?
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Yeah, it sounds like it runs fine - but that wasn't what I was asking. Is it always driven around town at low RPM or do you wind it up past 4000 every now and then?
Sometimes long periods of high RPM can be good for an engine and free up a stuck hydraulic lifter. Deposits build up on the valves, etc, if the engine is just loafing around.
A seafoam treatment in the intake/oil could also do it well. Someone shut up a ticky lifter on theirs with it recently.
https://www.matthewsvolvosite.com/forums ... =1&t=45554
'98 S70 T5
- whilst
- Year and Model: 1995 854T
- Been thanked: 2 times
Hi. I would replace o ring seals on oil pump intake first.
Check for oil volume-start car,remove oil filler cap, it should be "flooded" w/oil w/idling.
Made a world of difference on my '95 T,had 120K;now 220K.
They are going to need replacement anyway-critical! Provides lube to ALL of engine-read: Turbo,etc.
You may also wish to try Auto RX treatment. Some have had good results.
HTH.
Cheers.
HTH.
Cheers.
- 1101 Views
Last post by rspi
- 1673 Views
Last post by Redbox
- 987 Views
Last post by MoparWade
- 1766 Views
Last post by clifford06
- 21 Replies
- 3364 Views
Last post by rspi
