The seller sent me instructions relevant to an earlier version which includes the Vida Cert in the setup which checks computer hardware requirements during the setup. My 2011A version doesn't have this. I can install successfully regardless of date.
This requires that the system date be set earlier than Nov1 2008.
Jimmy the Vida status icon does turn green eventually. The Vida All-In-One service won't load unless it's green. It WAS going to a failed WSL login screen after submitting the password which just said "page not found"
With the patch installed it now says "This machine is registered as volvo" in the comments section under REGISTRATION GUIDE FOR SUBSCRIPTION
Once I reboot after the patch it says the same thing except uses the Computer Name
Now by submitting the wrong password it just says Invalid username highlighted in a red rectangular box.
DICE what can it do?
precopster
- Year and Model: Lots
- Been thanked: 128 times
precopster
I received my Vida copy from a UK eBay seller in this ad, installed it and it works fine:
http://www.ebay.com.au/itm/180790888139 ... 1497.l2649
The patch install location should have been route directory of 'C' drive instead of 'C/Vadis' but otherwise I'm happy to endorse.
I can run Dice with this install if I have the scantool . Unfortunately my Chinese copy of the scantool is not communicating with the car.
- 16721 Views
Last post by xiaofei204716
- 2384 Views
Last post by Orchid70
- 2217 Views
- 1164 Views
Last post by thr3shold
- 3250 Views
Last post by jwetering
