P0442 code
taylor98v70xcharris
Year and Model: V70 XC, 1998
Re: P0442 code
Post by taylor98v70xcharris »
Yes! very helpful thanks. One other thing, on cold starts in the morning iv seen a some blue smoke coming from the exhaust. could this be related to the code?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The blue smoke is unrelated to the EVAP system - that could be a clogged PCV system or bad valve stem seals that seep oil down into the cylinders overnight.
'98 S70 T5
2016 Chevy Cruze Premier
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
taylor98v70xcharris wrote:Yes! very helpful thanks. One other thing, on cold starts in the morning iv seen a some blue smoke coming from the exhaust. could this be related to the code?
Hi taylor98v70xcharris,
Have you done this one? Assuming V70 & S70 are about the same in this area?
Volvo S70 Evap Small Leak Common Problem P0442. Charcoal Canister J Hose Fix
As for the smoke it could be the seals per (jblackburn) & rings or first signs of a Turbo Seal leak. If your dipstick is blowing some smoke after warm up it is likely the PCV and/or rings (just age) otherwise see my comments below to drastically reduce or eliminate the smoke regardless if it is from the seals, rings or Turbo. I would recommend skipping the Swepco 502 as it did cause (clean) the Turbo seals (internal) to leak because there was so much build up (black thick oil when I got the car) that it leak out and smoked under the hood during warm up till I changed over to all Swepco motor oil 15-40W. No more smoke under the hood and when it was smoking I could see the slight oil drip on the bottom of the Turbo housing from under the car.
If you are interested please read my comments here.
https://www.matthewsvolvosite.com/forums ... 82#p231582
