P0442 code
taylor98v70xcharris
Year and Model: V70 XC, 1998
P0442 code
Post by taylor98v70xcharris »
Hello, first time poster long time reader, very helpful site. Anyway im the owner of a 98 v70xc and for the past three months iv been getting the p0442 error code. I know its a small evap leak but i was just wondering what are some things i could start checking? Iv replaced most of the vacume line (ran out of line :( ) and the "J" hose on the charcoal canister is fine. What else could it be?
Thanks taylor
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Have you looked at your filler cap - a poorly sealing cap will set an evap code. (Sorry if this sounds like an unnecessary note)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Purge valve OK?
The fastest and most thorough way is to have the car smoked for vacuum leaks
Dell+
Year and Model: 2001 V70 T5 5-speed
Post by Dell+ »
I've been having the P0442 code for quite a while. I got a new OEM gas cap ($26 :o ) and reset the check engine light. It came back in two days. I am getting it smoke tested next. Research has shown it could be: gas cap, J-hose cracked at canister (on top of fuel tank), purge valve, small leak in any vac hoses, mini hole in fuel filler neck, even a MAFS. so i am getting it smoked and will report my findings next week!
taylor98v70xcharris
All great advice, thanks all. Yeah changed the gas cap and most of the vac lines and checked the "J" hose they all seem to be fine. I hope its not a hole in my filler neck, that doesnt look fun to change. What would a smoke test coust me? just an hour of labor maybe?
Jag91000
Year and Model: 1994 850 Turbo Wagon
Post by Jag91000 »
about an hour of labor or so, my family's shop usually charges about 50-60 for a full smoke test.
Pauloil
Post by Pauloil »
you can check for vacuum leaks with carb cleaner also
99 V70XC 158K
95 850glt 188K
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1243 times
Post by matthew1 »
I've always been wary of this because of the heat/spark going on around the engine while spraying it. I'm no chemist, so perhaps it's unfounded. Anyone know for sure? Is propane better?
Also -> Amazon link
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
Hmmmmm.....I have a fog machine we used ONE halloween...I might want to try it. Any downside to sucking unknown chemical vapors into your vacuum lines?
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Hello,
I found this very helpful!!!!
How To Find A Vacuum Leak
