940 searching idle in cold weather
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Kirby J
Year and Model: 99 v70, 93 940
Re: 940 searching idle in cold weather
Post by Kirby J »
I also have a (93) 940 Rex/Regina with lots of miles (434k) In cold weather I have a similar idle problem, and problems with the cruise control. After the engine warms up, both problems go away. I have concluded that it is a couple of hard to find vacuum leaks that seal themselves once the hoses get a little warmer and more flexible.
Kirby J
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Then change those old rotten vacuum lines with some good reliable silicone tubing!
:lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Amys 940
Year and Model: 940, 1994
Post by Amys 940 »
My problem seems to be resolved. No up and down idle this morning! Although it was extremely warm today for this time of year. I would recommend popping off that old idle air motor and giving it a good clean. Use some good spray throttle body cleaner. I also was sure to push the plunger in and out as I sprayed to get it moving smoothly. While you're in there, replace the vac lines that go to it too!
Amys 940
Post by Amys 940 »
Nice job on the high mileage!! Original drivetrain?? I'm just hoping to make it to 300k. Only 91k to go!
regent
Post by regent »
Glad you sorted it!
2015 BMW 335i
