B+ battery cable: does the ipd aftermarket part fit?
This topic is in the MVS Volvo Repair Database » B+ Battery Cable
Has thanked: 2209 times
Been thanked: 1852 times
The upper one should have a wedged shaped piece of metal under the front hole and a bolt and washer if I recall correctly attached from the top. As you tighten the bolt the metal bar under it is wedged on the top and it squeezes the 2 sides together. I have only seen that version on a 96 850 I worked on a couple of weeks ago. If you look at the 4th picture on this link you can get a fairly good look at what I am trying to explain:
https://volvo850wagon.wordpress.com/201 ... rk-begins/
Like they guys say, this is not the B+ cable. That is typically a smaller cable that comes off the +ve battery cable and runs to the main fuse box. This may help you see the difference:
viewtopic.php?f=1&t=35208
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
This may be a sign that I'm a pack rat, but I'm hoping you all won't criticize me too much for keeping this old terminal for the past 11 years since removing it. You never know when you're going to need one and I'm generally inclined to save each piece I remove in case the replacement turns out to be a dud.
Positive terminal from 1997 855 GLT
View from side:
Side view of clamp
Side view of clamp
Not a pack rat, just a very wise man.............! :roll: :lol: :lol:
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
I assume the ground cable has the same connector. Maybe I can get back over to the junk yard and get lucky and it's still on there.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
The car I worked on had both of them with the same connector. So s long as some has not changed the ground cable you may be lucky!
Good Luck!
jmartin919
No luck. Missing the clamp on both. Discarded when the yard pulled the battery I guess.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
