What has failed on your 1992-2000 FWD or AWD Volvo?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I think I checked over half of the things on that list.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 2864 times
- Been thanked: 1332 times
Poll options updated as per requests.
Ben850
- Been thanked: 7 times
I don't know if it is working for everyone else, but I still cannot add to the list. Maybe I permanently locked myself out by voting before the fix? It's alright, Just imagine about 3/4 of the list and a few that aren't on it.matthew1 wrote:Poll options updated as per requests.
Enjoy.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Significant item missing, at least from my wallet's point of view, steering rack. Blew every seal on winter. Passenger front wheel bearing has failed three times in 10 years of ownership. Currently troubleshooting rear wheel, stay is broken, undetermined cable connection is sheared at splice near control arm. The joys of car ownership.
GB3
1964 P1800
1998 XC70
2012 C30
1964 P1800
1998 XC70
2012 C30
aahmes57
Pretty much alot. Bought it for $3200 and I have about $2000 (not counting any misc labor) in parts in it. PCV system, both cam and crankshaft seals, oil coolant lines, struts, ball joints, axles, tie rods, rotors, ABS module, heated seat switch, rr window switch, rear shocks, t-belt and associated components, drivers seat switch, and a few others that escape me at the moment. Runs great at 190,000 so I guess I'll keep it.
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
1995 850 sold
mynorsyama
Dashboard backlight
Horn switch
Radiator fan
Headlight switch
Internal Fan switch
Recirc valve
Horn switch
Radiator fan
Headlight switch
Internal Fan switch
Recirc valve
Colonialgirl
- Year and Model: S-70, 1998
I just had to have the Cam Shaft Seals replaced on my 1998 S-70 (Non-Turbo) I was losing oil there like crazy; Thought it was the PCV Oil Separator, BUT after replacing the seals, they checked the crankcase pressure and found ALL to be normal.
BTW, If you are around Tampa or Brandon, FL; Bergman's Foreign Auto Service did an excellent job at a reasonable price and were up front about what was needed and didn't add on to the costs.
I forgot to check (1) shift-lock microswitch and (2) signal flasher relay for my 1996 850.
Other things:
Other things:
- Misc lights in the dash/radio.
Backlight for PRND3L.
Driver window button fell apart.
Speed sensor at trans went in and out.
Steering column cover secures broke.
Horns died early on.
The Good - 1995 850 Turbo
The Eh... - 2004 Ford Focus
The Dead - 1996 850 GLT - The bane of the Grand Cherokee..
- 1620 Views
Last post by foggydogg
- 2536 Views
Last post by RickHaleParker
- 804 Views
Last post by ddavis6900
- 2668 Views
- 2398 Views
