Do this. It may cure the stalling.jblackburn wrote:After replacing vacuum hoses and that intercooler hose, reset the computer...yank the negative battery cable, step on the brake pedal, and then reconnect it. See if it stops cutting out on you after that.
FYI, it will idle a little funky for the first 2-3 trips after doing this, but it will then smooth itself out.
95 850T full throttle, no boost
- Has thanked: 2864 times
- Been thanked: 1332 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Thanks Mathew1. Just found the opportunity to lock my keys in the car at my cousins house for 2 hours at Position 1 so I can get the Radio unlocked and now one more timematthew1 wrote:Do this. It may cure the stalling.jblackburn wrote:After replacing vacuum hoses and that intercooler hose, reset the computer...yank the negative battery cable, step on the brake pedal, and then reconnect it. See if it stops cutting out on you after that.
- 2673 Views
Last post by gmtgmt
- 1929 Views
Last post by fisker247
- 16 Replies
- 3356 Views
Last post by MadeInJapan
- 504 Views
Last post by MOZKNBBUHD
- 13 Replies
- 2501 Views
Last post by bronco
