Open the hood all the way, see step 2 here:
http://www.atthetipwebs.com/technologyi ... filter.htm
'97 850NA-7 bolts are off, but water pump won't...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
thecheat
- Year and Model: 1996 850 Turbo Wagon
The factory pump is practically glued in to the block. It's possible that this has already been replaced and was glued in with something even tougher to break.
I can only echo the above advice... swat the pulley with a piece of wood and a mallet. You will need to clean off the gasket adhesive left over.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The installed is HEPU, replacing with AISIN.
I must keep the Cam locked with IPD tool during this effort, a realization, I could no longer pussyfoot around.
thecheat
A lot of folks don't use the cam tool... I don't know if the cost of the tool and the wait for shipping offsets the aggravation of having to line the cams up by hand. I can say in my case the exhaust cam kept rotating backwards from the valve springs pushing on the lobes. It was a real SOB to get the belt on and timed right but I managed in a couple hours.
xHeart
Used 2 feet long round oak wood banister piece with a slugger's left-hand grip, pointed it at 2 o'clock position, and whacked it with mallet, two quarter swings.
Smile! I am feeling better.
Thank you so much!
Thank you so much!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Huzzah! Brute force for the win!
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
I felt bad hitting it hard without cussing. Thinking and patience is an awesome combination.
- rspi
Contact rspi..
Hurrah!!!
- 520 Views
Last post by DXC70
- 1983 Views
Last post by MadeInJapan
- 30 Replies
- 1531 Views
- 1302 Views
Last post by Nevada1906
- 5013 Views
Last post by kallekula
