Where to locate jack stand...
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
FWIW,
Watch this video and see where they place the support (at 0:38 marking):
Post by cn90 »
In other words, the jacking points (according to the above video) are just behind the subframe attachment points:
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
cn90 wrote:xHeart, not to change subject, but in your other posts, your subframe bushings at 120K look fine to me.
I see no need to replace your subframe bushings.
I will assess it again tonight.
What appears to be a 1/2" gap between the bushing and bracket mount. The gap gradually widens when subframe is rested on jack stand, while I begin lowering the Volvo jack from the lift bracket below the door/frame. It is greater at driver's side rear subframe.
I will take better photos for comments before starting any work.
Stay tuned...
xHeart
Post by xHeart »
After brief pause...
A safety drill before actually doing the work.
Used the 2.5T floor-jack from the front to raise the car, and then placed the two jack-stands under the subframe near the control arm on each side.
two jack-stands located near control arm supporting the subframe
Taking a closer look at the subframe busing during this safety drill.
passenger side rear subframe bushing in proximity
Below is a photo of frame surface area next to the mount plate.
Is this the safe location to place the jack-stand on each side before working with replacing the rear and front subframe bushing?
frame surface behind the rear bushing mount plate
Adding new rear subframe bushing photos for your comments in my "Is this collapsed..." viewtopic.php?f=1&t=51781.
xHeart
Post by xHeart »
The frame surface looks beat up and missing the round rubber cup, it is visible in the driver side photo above.
Do I need to place the round rubber first?
Would it improve safety?
passenger side frame surface with missing round rubber
xHeart
Post by xHeart »
I have been using volvo jack at the jack rail located under the door to raise, then i would place a jack stand under the subframe to work.
Often asking myself "How will I prepare for this task".
Recent needs to replace suspension parts, axle boots, and general upkeep of items connected to subframe, I am starting to practice safety. Raising car, supporting subframe, accessing work area, relocating jack stand, and reading and applying MVS DIYers methods. Replacing with quality parts, acquiring right tools, and wait if not certain.
Photo below was taken while assessing wear on subframe bushing, and ways to safely reach and work with components for replacing subframe bushing.
Always looking to improve, please comment.
Left the car raised for several hours. Paid attention to movements and sounds when raising, supporting and lowering.
