Affordable, stand alone(?) Code reader for 98 s70, NA automatic
utilityaudio
Year and Model: '98 S70 GLT
Has thanked: 36 times
Post by utilityaudio »
Hi folks,
Is there such a thing as a *good* reliable scanner for a 98 S70 that's reasonably priced? Preferably either stand alone like an OBD-ii reader or a Bluetooth connection to smartphone (android preferred) +application?
I've used an OBDlink LX which has been reliable but not detailed.
I also tried an el-cheapo bluetooth obd reader and an app "850 OBD-ii" app which seemed to get details, but literally only worked once... I got excited because it worked and didn't take screenshots because I knew I could get back to it later...
I'm not interested in running a vm with VIDA/VICE if there's any alternative.
I'd really love to be able to reset the "service" light.
I am currently getting a code for an O2 sensor but can't tell which one.
I also have an issue with tracks/abs.
Does something like this exist, or am I being naive?
Thanks for any information you can provide, even if the answer is "no"
Has thanked: 1609 times
Been thanked: 4065 times
post up your codes on your OXS as they have completely different functions, and so only overlap on heater current faults.
AUTEL makes a good series of scanners and the one that will let you read codes and data runs about $150 on Amazon
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I’ve used an iCarSoft one off Amazon and has worked well on my P1 and P2 Volvos.
08 C702.5T (sold)
The non-Swedes:
Has thanked: 2199 times
Been thanked: 1851 times
My Autel resets the service light on the 96-98 cars. However, it is an 802 which is a higher end unit.
A laptop, a Vag-com cable and a free download of Vol-fcr will also do your checking, but is not really very portable.
I looked at the iCarsoft but it does not work on pre-00 cars that I recall.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
For $6 or $9 dollars you can obtain the most common codes and reset them. I have not tried the $9 iOS & Android. The free Car Scanner software is easy to use and full featured.
viewtopic.php?p=634816&hilit=obd2#p634816
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
utilityaudio wrote: 28 Oct 2023, 22:13 I also tried an el-cheapo bluetooth obd reader and an app "850 OBD-ii" app which seemed to get details, but literally only worked once... I got excited because it worked and didn't take screenshots because I knew I could get back to it later...
So get a bit better OBD2 Bluetooth dongle? I bought the one that RobertDIY recommends, I think. It works pretty well for me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
aeg
Year and Model: 97 850GLT
Has thanked: 2 times
Been thanked: 46 times
Post by aeg »
It looks like OBDlink LX is ELM327 compatible, why not use that with the Android app?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
I'd just look for a new/better BT reader and use the "850 OBD-II" app. It's pretty comprehensive.
I've had the same "cheapo" ELM-327 reader for several years, and it has worked for the OBD-II app, Carista, Torque, etc.
(I use the Carista app to get quick reads/resets, but the OBD-II give much more utility when I need it)
