DIY: 1998 V70 T5 Turbo inner/outer tie rod R&R with pics
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I believe most TRW and ZF steering rack have similar setup.
In my 1998 BMW 528i, the INNER Tierod needs the 32-mm wrench ($15 online).
Now if you own a BMW, then you will know the tool, it is the same tool used to loosen the Fan Clutch Nut in the BMW.
Here is the tool in my 1998 BMW 528i, you can see the 32-mm wrench:
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The granddaddy "inner tie rod removal tool" is the simple pipe wrench.
Cheap, easy to use, you likely already have one, and on these cars it will work every time.
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
erikv11 wrote:The granddaddy "inner tie rod removal tool" is the simple pipe wrench.
Yes it does! :D
JollyJohn
Year and Model: v70 1998
Post by JollyJohn »
Getting ready to attack the inner tie rod end.
Has anyone out there looked at replacing the oil seal on the rack where the "piston" comes out of the rack ?
Daughter has been running without PS as it leaks so badly that it won't keep the fluid in.
Thanks in advance,
John
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
update:
Steering is super tight and responsive after 6 months. :mrgreen:
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
98T5
Post by 98T5 »
JollyJohn wrote:Getting ready to attack the inner tie rod end.
Thanks in advance,
John
haven't had that issue yet. but if you can fix it, post pics. :mrgreen: I'd like to see how that's done.
Post by erikv11 »
There have been several posts about this recently on Volvospeed. You can do the passenger's side with the rack in the car, but not the driver's. I'll try to look up a link later tonight and post it if no one else has by then ...
Post by erikv11 »
Here is a thread with a few pics and diagrams, outlines the basics:
http://volvospeed.com/vs_forum/topic/15 ... -leak-fix/
