Need help with setting sequence of repairs
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
It wasn't easy, but turned.
I had to heat it a dozen time, one minute at a time. The blue flame was right-on, while rotating the outer-tie-rod 90º every 15 Sec to heat it up evenly.
Would heating it for longer than a minute help ease the use of force when turning with wrench. It is really hard, I stopped b/c it...
loosen one thread...
Leaving it overnight with PB Blaster.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Now spray some PB Blaster and let it sit overnight.
xHeart
Post by xHeart »
cn90 wrote:Now spray some PB Blaster and let it sit overnight.
At the first try the gap at lock nut widen a little when turning the outer-tie-rod with counter-holding at the lock nut, suggesting both the inner and outer tie-rod were turning together.
Then switched to a counter-hold on inner-tie-rod, it started to strip (close to rounded) after several attempts to force the outer-tie-rod counter-clockwise.
Little frustrated with little to no progress.
stubborn as hell
stubborn as hell
xHeart
Post by xHeart »
DONE! Beating chest!
Thank you!
Ben850
Been thanked: 7 times
Post by Ben850 »
This may be a silly question, but if you are doing the inner and outer tie rods on that side, Why not just cut the boot and unscrew them from the rack together? You must have been quite frustrated from the looks of that tie rod.
Ofcourse I planned on replacing the boots as well.
That would also give you a very close measurement for the new ones. I think that is what I did with one side at least.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Post by cmblackburn »
That's what I'm thinking about doing as well. I'm replacing both at once. Seems like it would be less trouble. :wink:
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
schmidm90
Year and Model: 2000 V70 XC AWD
Post by schmidm90 »
I ordered a new inner/outer tie rod for the driver side and plan on removing both at the same time right at the rack. This will allow me to get an "accurate" measurement for the new ones. Thanks to FCP for the cybersale!
Will keep everyone posted on how it works out!
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
xHeart
Post by xHeart »
Euphoria!
I have completed ALL items set in my OP. I mean 5 days of work with daily chores of living.
It takes the road like a pro.
Post by cn90 »
Wow, great job.
Nothing beats a strong human will!
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
xHeart wrote:Subframe components are key to restoring stability, but often ignored. Suspension steels the show.
Can you elaborate on this? And any lessons learned from having done your subframe bushing?
2003 XC70 230K and counting..,
