96 Volvo wagon control arm replacement
Volvo S70, V70, XC70, 850 Control Arm Replacement
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
One of the most important steps in the entire process is loading the arm to the ride height before you torque the frame bolts. If you fail to do that you will destroy the frame bushings and they will wear out very fast.
2forty
- Year and Model: 850 1996
- Been thanked: 2 times
I used a floor jack and lifted the wheel hub so the center would be in the middle of the bottom of the door and the bottom of the door frame as stated above so hopefully I got it pretty close.
- BobbyC777
- Year and Model: V70 2.5T, 2004
- Has thanked: 27 times
- Been thanked: 7 times
Great write-up, Lee and good tips from others.
What symptoms are exhibited that would tell one that new control arms are in order?
Thanks.
Bob
Thanks.
Bob
- rspi
Contact rspi..
Best to jack the car and check the wheel for movement, 3 to 9 and 6 to 12. My first indication was a slight pull to one side when I braked to stop occasionally. You should have NO wiggle movement in the bushings.
- Has thanked: 312 times
- Been thanked: 818 times
Worn bushings usually manifests as a click in the suspension when starting or stopping the car. As the car lurches one direction or the other, the control arm shifts in the bushing and clicks.
It is much more common, and more worrisome, for control arms to fail at the ball joint. While failing bushings are annoying, a failing ball joint can be dangerous. Car wanders or jumps around on the highway, loose steering. Front tires may show uneven wear. If it fails completely the wheel will fold out. But complete failure is extreme and rare, you'd have to ignore a lot of signs.
Checking the wheel for movement as rspi stated is a good way to investigate. The key is to look at the suspension linkage while you wiggle the wheel, you need to see where any motion is coming from. Like the bushings (in fact like every joint in the suspension linkage), the ball joint should have zero movement.
- Year and Model: Many Volvos
- Been thanked: 76 times
The alignment may or may not change much, it depends on how good things were when the last alignment was done. It will be slightly different no matter what but it may or may not be significant. An alignment is advisable but not absolutely necessary. The mechanics suggestion is prudent and he isn't just trying to rip you off. You can always decline.hot9000 wrote:Thanks for the information. Very useful!
BTW, my mechanic told me to add "wheel alignment" after the control arm replacement. Is it necessary or am I being taken advantage? Thanks again.
akwon
- Year and Model: 850 GLT 5dr, 1996
- Has thanked: 3 times
Another small tip I came across after replacing my control arms: sand the inside of the subframe brackets where the control arm bushings fit in. Mine had a lot of gunk and rust built up so I could barely get the control arms fitted and positioned at first.
1996 850 GLT 5dr, 219xxx km and a broken odometer
1st car, 1st Volvo
plan to drive this thing into the ground
1st car, 1st Volvo
- 13360 Views
Last post by MarcM
- 3037 Views
Last post by 800artfreed
- 25 Replies
- 5260 Views
- 1155 Views
Last post by s_watts
- 4223 Views
Last post by Tonyx
