DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Those connections look great! Where did you get the nice set of Oetiker crimp pliers shown in the first photo?
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
whats everyone's thoughts on a front mount trans cooler ? I got one off a caddy at the JY and installed and it seems to be working great. Im planning on installing a in-line trans filter as well....
1996 Platinum Edition
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
jreed wrote:Those connections look great! Where did you get the nice set of Oetiker crimp pliers shown in the first photo?
Jason,
I got these Oetiker clamps on ebay for cheap. Thee is an ebay seller named john102561.
He sells Oetiker clamps, usually a set of 10 for $2.50 ---> $3.00.
This is what I did:
- Go to ebay and search "Oetiker clamps".
- Find john102561 listings.
- Buy different sizes: I bought 8mm all the way to 16 mm. It cost me some $25 for this assortment.
- Then I store them in well-labeled clear plastic container (hardware store sells this container for $4).
You will appreciate this collection when you need to fix odds and ends and need an Oetiker clamp in an instant!
BTW, It is much more expensive to buy a ready-made Oetiker assortment box ($60+) and they usually do not have the assortment you want.
jreed
Post by jreed »
Thanks! Looks like a great deal on Oetiker clamps.
Post by cn90 »
Another follow-up, almost 2 years later, nice and bone-dry, absolutely no leak whatsoever.
Redneck
Year and Model: Volvo 854 1996 GLT
Has thanked: 10 times
Post by Redneck »
@cn90. That is a great repair idea. I'm already buying parts and will keep them until I get a leak, or when I replace my ATF next time.
Post by cn90 »
Two (2) + years and 25K miles later...the rebuilt hoses look fine, zero leaks.
Just an update...
Post by cn90 »
UPDATE:
- It is now 4.5y/40K miles later, this rebuild using generic trans hose still holds up nicely.
Oitsujosh
Year and Model: 99 V70 XC
Post by Oitsujosh »
Cn90, awesome write up! I had the oil cooler line start leaking on my 98 xc70 last week, and I used this method. For those that want to fix the oil line with this method, you will need larger line than the 3/8". No auto parts stores local had a size large enough in trans line. I wound up at a local hydraulics company and got some 1/2" line. The old line is a 12mm line, but I wasn't able to find it quickly, the 1/2" fits bit not as snug as I would like to see it, so I used a little soft setting sealer on it just to make sure it didn't leak. So far so good near 500mi on it. I'll update later on for you guys.
99 V70xc Darkwing (goneπŸ˜”)
08 xc90 Tabitha
06 V50 T5 Awd 6spd. Skeeter
66 barracuda "very long term project"
Post by cn90 »
UPDATE 4y/40K miles later.
- Zero leaks, Oetiker clamp area looks good.
- @Oitsujosh, my 3/8-inch hose is fine. I don't know about XC model, but for FWD model, the 3/8" line is fine.
