PB Blaster vs. Kroil
Re: PB Blaster vs. Kroil
Does it need to be any type of specific ATF or any will do in the ATF 50 percent Acetone 50 percent mix? I think I have both of those in the shop already.
04 VR M66 Manual Trans: Parting Out
06 VR GT Sonic Blue/Gobi
94 300 ZX TT: M/T
94 300 ZX TT: M/T
Ben850
- Been thanked: 7 times
In my desperation, I will be changing the rear calipers no matter what.
I will give tis stuff a chance. The CRC Freeze-Off.
Not vouching until I see the results.
- It makes sense to throw liquid "cold" into the mix.
- Crc-Freeze-Off-Super-Penetrant.jpg (4.23 KiB) Viewed 1091 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I posted up the original report below. It looks like the test was done on 1/4" diameter dowel pins press fit into 1/4" diameter holes drilled into low carbon steel. Salt and heat were used to accelerate corrosion. Then the parts were soaked for 12 hours in the various mixtures. A compressometer was used to measure the force needed to move the pin in the hole.
- Penetrating_Oil_Test.jpg (109.35 KiB) Viewed 1084 times
