Like I say I've lost oil pressure in mine so many times (I'd say at least 20) over the last three years (and 30K miles) and it still runs pretty damn good, considering that.
Run some xW-40 in there and see how it goes. You'll get a while out of it yet for sure... It's not worth digging deeper and you might still get 20K miles out of the motor.
2001 S80 No Engine Oil Pressure at Idle
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Problem with that is mineral based oil will increase the risk of clogging up of the oil journals etc which may further affect oil pressure.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It's not the mineral oil itself, not even the oil change interval, it's the stupid crankcase ventilation canister that was killing those engines. That model of the PCV caused the same issues in other cars, BMW for example. Even people that used only synthetic oil with 4000 miles change interval had the engine clogged and busted. It occurs regularly every 80K miles, that's the life expectancy of the canister, actually that's when it's too late.difflock54 wrote:Problem with that is mineral based oil will increase the risk of clogging up of the oil journals etc which may further affect oil pressure.
- oragex
That would be an excellent idea for this cars.astouffer wrote:How about installing a real oil pressure gauge to monitor whats happening?
wildzontar
- Year and Model: 2001 S80
We did that at the first shop, that's how I know it's "barely sufficient".astouffer wrote:How about installing a real oil pressure gauge to monitor whats happening?
The low oil pressure is established, what's causing it has not been conclusively determined, although I think the consensus opinion I've accepted after almost all the possible repairs have been done, is that the engine is simply worn.
- oragex
You say your idle is below 700rpm? I don,t know those engines, but is that idle normal? On my S60 it's rather around 850 rpm. If the idle is too low, I guess oil pressure will be lower?wildzontar wrote:We did that at the first shop, that's how I know it's "barely sufficient".astouffer wrote:How about installing a real oil pressure gauge to monitor whats happening?
boosted5cyl
Is your S60 a 5cylinder? typically they idle higher as they are not as balanced as a 6. T6 should idle around 650-700 from memory.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Due to emissions requirements the P2 turbo 5 cylinder engines idle much lower at around 580rpm
- 1382 Views
Last post by crussell83
- 1420 Views
Last post by Salomons Driveway
- 2161 Views
Last post by fitz548
- 4007 Views
Last post by matthew1
- 16 Replies
- 2968 Views
