They're like $70 from fcp.
I got the negative cable from fcp for $100 and replaced it but I still have an intermittent starting issue, this positive cable is next.
Alternative to replacing positive battery cable
¡Vivo! 850 T5 16T 019-Black Stone
0-60: 5.7
1/4mile: 14.3
Vmax:North of 160mph
RSPi: "That's why we drive old cars and try to act proud of it."
FOR SALE: WHITE INJECTORS/BLUE INJECTORS/S70 MARKER LIGHTS
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Great write up! I like it!
The cable I used came from IPD and it was about $40. I think it's the same cable that FCP lists. They come from RAMAC. IPD doesn't list the cable as compatible with the 850, but it is if you make a minor modification to one of the terminals.
IPD $36:
http://www.ipdusa.com/products/6379/115 ... 70-v70-c70
FCP $73:
http://www.fcpeuro.com/products/volvo-b ... 70-9456836
IPD $36:
FCP $73:
SO I am having some weird issues with my 99 s70 and I am looking at replacing the B cable , the battery cable and cleaning the grounds.
My symptoms are : ABS, TRACTION,BRAKE, up shift arrow all lit up and the right hand turn signal lamp in the dashboard is not working and it runs like crap. I have already changed the ABS mod and the ignition switch....no change...
I did a simple voltage drop test and it was minimal....but this was done at the problem was not occurring at the time. I only tested it at the fuse box not the back fuses. I also did the system charging test and it seems fine 13.24 engine off ; 13.65 running no load; 14.10 engine running and full load...but again...the issue was not occurring when I did these tests and the car was not warm..
Do you think I have a cable problem as well?
- Has thanked: 1611 times
- Been thanked: 4071 times
Ive always made my own but I have the crimping tool since Im a sailor.
If you use marine rated wire it will corrode less than the cheapest stuff, but costs 2x too
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Maybe that was my deal, I was looking at both parts/cables.KllewT5 wrote:They're like $70 from fcp.
