I wrote the procedure for the 2.5T below, V8 a bit different:
https://www.matthewsvolvosite.com/forums ... 10&t=64335
2010 XC90 V8 (AWD) Anyone doing transmission flushes?
XC90 3.2 V8 Transmission Flush, Incremental, or Don't Touch?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Remove the TX40 center plug from drain plug. Use a 17mm hex key or a 17mm bit and remove the drain plug.
Partially or completely remove the air filter housing so you can access the TX55 fill plug on the forward outboard side of the trans top.
Install the drain plug and tighten. Install the center TX40 level check plug snugly.
Add 4 quarts ATF to trans through fill hole and install and tighten the plug.
Set air filter in place and start engine. Allow engine to run 10 minutes and put in D and in R and then back in P. Remove the check plug and allow the extra fluid to run out. It will be 8-12 ounces.
If you leave drain plug out for hours then you need to put in more fluid. 12 or more hours may need 5 quarts as the torque converter will drain and cause more to be in sump to drain out through plug.
- 2243 Views
Last post by JMEngland88
- 1645 Views
Last post by JenShazaam
- 257 Views
Last post by skheng2656
- 1005 Views
Last post by nameuser
- 2886 Views
Last post by robrike
