I braced all of my mounts. Three were broken.
Maybe you can screw a different kind of screw in the 2 holes that you couldn't get to catch. Some metal self tapping screws or something. If that works you may not have to install this new dash.
1999 S70 Dash mounts, should I reinforce?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: 1999 S70 Dash mounts, should I reinforce?
- rspi
Contact rspi..
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
I see you did your metal bracing going over the top and bottom of the mount, while the other person in the picture above went around the front and the side of the mount, wouldn't your way keep the mounts in place as opposed going around the front of the mount, I don't understand how both ways can work the same in holding the mounts. Or am I missing something?rspi wrote:
- rspi
Contact rspi..
I thought that I could get better support and tighter support going the way I went.
burnout8488
- Year and Model: 1999 S70 AWD
The Bondo fiberglass kit works well for this. Available at Walmart/autozone/etc. in a small black box.
Lay down the resin-soaked fiberglass pieces around the mounts and build it up in 2-3 layers, one layer at a time allowing it to cure between layers. Rock hard, no fiddling with glues or pastes, brackets or screws. You can put the fiberglass pieces behind, inside, around the plastic mounts.. just as long as you leave a hole for the bolt to go through.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
