ETM software
Same part numbers as in the picture under the barcode they matched ETM I bought perfectly. It is very clean and in perfect condition as far as I can tell. I had to put the old one back in and deal with the losing throttle problem... But at least it idles right.
2002 V70 2.4 Basic 181,000
Previously owned 1987 240 345,000
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
That means dealer tries to make you to by the brand new one.
Try to find someone with DiCE and I will transfer software from old to new.
If you have questions about Volvo firmware ask me. I may know an answer
Yes that's what he said the only way to fix it is for them to put a new one in and redo the software. I don't know anybody with dice but I found them for sale $100 and will buy if I'm sure this will fix the problem...
Will I need anything else such as cables etc.?
doublebug
Try to ask on the forum if there is somebody nearby with DiCE.
Remember you need the right clone of the original DiCE (off course original will do too
I am still using the old throttlebody and dealing with the issues. Which are rough starts and Idol and no power then I pull the fuse number 23 for the ECM out for 20 seconds put it back in and then it will start and idle fine. I can drive like this for a while then it goes in to the limp mode in which I can only do 15 mph but after 30 seconds to a minute of this and playing with the throttle while driving it kicks back in And drives fine. The new throttle body that I got off of eBay when I put it in it starts but it seems to me like it's running real rich and idles high and rough. Help plz
doublebug
Actually dealer cannot install an used unit to the car (it is prohibited by strict manufactures rules).
But if you install it yourself and ask dealer to reload ETM's software not saying that is an used one.
That may work.
That may work.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Thar's a great hint doublebug. It may save many users lots of dollars.doublebug wrote:Actually dealer cannot install an used unit to the car (it is prohibited by strict manufactures rules).
That may work.
Ok , Got the e-bay ETM in and running great thanks to doublebug transferring the software. There are no words to express my gratitude for what you have done for me. Many thanks, Carter
precopster
Doublebug sure is a busy boy!! He transferred some software over for me last night as well!!
Glad it went well for you.
- 1707 Views
Last post by the65dartguy1
- 1897 Views
Last post by Tim
- 2387 Views
Last post by precopster
- 1789 Views
Last post by aanalla2
- 2240 Views
Last post by RickHaleParker
