I had all the main engine seals (cam/crank/oil pump 'o' ring) replaced at the dealer using OE parts. The crank seal was leaking by the time I got home! Just had it replaced again, and all seems fine for now.
If you have had problems with the PCV, it can easily blow out a seal. The crank seals and rear 'front' cam seal at the pulley are both known to be difficult to seat correctly even by the experts.
There is no easy way around this, but still recommend you make sure you clean the whole area off again, and take for a short run, or run the engine for a short time and watch it. The oil could just be stuff picked up by the cam belt and being thrown around the engine bay.
Once you have done this it is time to pull the belt and find out what is going on.
1998 S70 GLT Continuous Mysterious Oil Leak
- Has thanked: 2203 times
Wallymoose
- Year and Model: S70 1998
Make sure your rubber seal inside your oil filler cap is nice and flexible - It will get rigid in time - I had a great deal of oil in the engine bay and that $3 part fixed it - Simplistic but worth trying
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Check the black 10mm bolts on top of engine to see if one might not be tight. When I bought my car a year ago, I had a leak that filled up the top of engine and sparkplug holes. Oil would puddle up and run down the back of engine. Found out one of the black bolts was loose.
- 747 Views
Last post by waynegarbo
- 13 Replies
- 2477 Views
Last post by RickHaleParker
- 768 Views
Last post by oragex
- 225 Views
Last post by firstv70volvo
- 9176 Views
Last post by ggleavitt
