1996 850 => Check my Plugs Please
JDS60R
- Been thanked: 3 times
Re: 1996 850 => Check my Plugs Please
Yes today they are shipped better and regap is only for racing or if they are dropped.
Retired
jose456891
- Year and Model: 850 GLT 2.4 1996
I already ordered the cables (Bougicord), and I have a set of cap/rotor left behing by the previous owner. I'll rebuild the fuel relay.erikv11 wrote:oops - i missed where you said you already put in OEM plugs. That's a great start.jose456891 wrote:The OE plugs had a smaller gap, very small center electrode, and multiple prongs. Hopefully this is it, otherwise I'm moving to cap+rotor/coil/wires/fuel relay.
Thanks!
If you do go to the next stage of parts, wires must be Bougicord and cap/rotor must be Bosch. Coil is very rare to go bad on these cars.
I'm hoping this is it.
jose456891
This is not it. The car gave me the following codes:
P1310, P0302, P0303, P0304, P0301, P0305, P0300, P0422
I expected the P0422 because the CAT literally spat its guts out.
Today I replaced the wires, cap and rotor with used ones. The wires had 2k, the cap and rotor looked good, they were left by PO in the spare tire compartment.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Jose--
Just a quick follow up to ask if replacing the distributor cap and rotor and ignition wires solved the multiple misfire problem you were having...
I ask because yesterday after a hot restart my wife noticed the car misfiring and nearly stalling. I pulled the same codes you got: P0300 (multiple misfires), P0301, P0302, P0303, P0304 and P0305.
It's been about 60K miles since I replaced the cap and rotor so it might be time to go in there again.
Jose- I had those issues/codes when my cheapo aftermarket MAF sensor was in the process of crapping out a couple years ago. Began with fluctuating RPMs at idle and P030X codes. Then tripped P0172, P0422, P1310 and black gunk started spitting out in the exhaust. Disconnecting it can apparently help diagnose it (didn't work for me) and cleaning it didn't help at all, but it might be worth trying those things because it's cheap and easy.
