Correct, I also used it like this and this is working on my Volvo S80 2.4T (200BHP).db130 wrote: 12 Apr 2015, 18:50 Are you sure about that? I used the same MAC solenoid back in 2010 for a 98 S70 T5 and I used:
Port 1 - fresh air
Port 2 - wastegate
Port 3 - compressor
Build your own TCV, save 50%
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
precopster
- Year and Model: Lots
- Been thanked: 128 times
Had it sitting around for over a year and fitted it today. Why oh why didn't I do it earlier!! Car now redlines quickly and never hesitates.
precopster
As another follow up to the installation of the Mac boost valve I have far better cruising fuel consumption. At steady 80kph (50mph) I'm getting between 38 and 42 mpg depending on the gradient. It's still a pig on fuel around town and that's understandable given its weight.
So by all accounts if you're a highway driver this is the ticket and has already paid for itself in the fuel savings. BTW I went for the cheapest one I could find with fittings and fabricated my own connector to match the car loom.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Anyone have a source for the plug/terminals?
I'm coming up empty on finding the 979153 plug.
I could make my own connector, but that would negate reinstalling the stock type, if needed. (Not too big of a deal, really)
precopster
I used a Dremel to cut the connector off the original Pierburg unit then soldered the leads to the exposed terminals. It doesn't look pretty but does the job.
After that I used an epoxy to insulate the terminals so I can go back to a spare Pierburg unit I have if it fails.
- Chuck W
I guess that's an option, too. I know I have a couple floating around.
I do have this older IPD BCS that came with a motor I just bought, that I could grab the pigtail from, also.
precopster
I've swapped in TCVs where a BCS is fitted to earlier cars. They have the same function electrically and mechanically.
acrazyjohnny
- Year and Model: 2003 xc70
If anyone wants to buy the ipd style actuator and not the MAC one its made by Ingersoll. I have it on my other car
- ndphotonl
I have been using the Porsche TCV for quite some time with good results, highly recommended. Costs about 25-30 euro/USD
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
acrazyjohnny
i had the same issue because it was a typo. if you look at the original post pics you can see part number is 978153Chuck W wrote: 10 Mar 2019, 13:33 Anyone have a source for the plug/terminals?
but by the time i figured that out i had already ordered a set of 5 male plugs and 5 female plugs
- 3142 Views
Last post by Rucho26
- 5467 Views
Last post by matthew1
- 66 Replies
- 6725 Views
Last post by MrAl
- 49 Replies
- 1941 Views
Last post by MrAl
- 1631 Views
Last post by EuroDriver
