1999 Volvo XC-70 Replaced fuel pump car still doesn't run
pavendan
Year and Model: 1999 Cross Country
Re: 1999 Volvo XC-70 Replaced fuel pump car still doesn't ru
Post by pavendan »
CN90,
I got .4 Ohm (31 & 87) and almost no voltage between 31 and 31b
Patricio
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
pavendan wrote:CN90,
...almost no voltage between 31 and 31b
Patricio
Was key in position II during this test?
Post by cn90 »
31 is ground.
31b is controlled by the ECU, and has voltage of 4.3V, when key is in position II.
When you turn the key to position II, 31b is fed with 4.3V by the ECU.
This closes the primary circuit (31 + 31b), activating the secondary circuit, which closes 15 and 87 ---> activating fuel pump.
I suspect the PRO part to be the problem. Bosch is OEM.
Has thanked: 1503 times
Been thanked: 3817 times
That 0.4 Ohm means with 12V applied, the pump should pull about 30 AMPS
Not good, and surprised the fuse doesn't go
pavendan
Post by pavendan »
Yes the key was in position II. Where can I order the Bosch pump for that price?
Patricio
Post by cn90 »
Ebay has the Bosch fuel pump for $85 or so. Ask the seller to be sure it is Bosch OEM before buying it.
