Volvo 850 Junkyard haul
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Hah, another Triangle-area Volvo owner. I saw that one in the "processing" lot two weeks ago.
There's some good finds out there if someone hasn't got to it before you and smashed the heck out of everything. I took the climate control unit out of one of the 850's out there (I think it was green?) and sent it to someone on the forum here.
I did like seeing a car like my car before the Volvo being crushed by another. Miserable POS.
'98 S70 T5
2016 Chevy Cruze Premier
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Just got back from a further adventure thru the junkyard. There was a '96 855T with about 250K miles. I wanted to share a photo of an ingenious substitute that somebody had concocted to make a replacement for the upper torque mount rubber bushing:
Canvas strap replacement for rubber bushing
Bodged rubber bushing '96 855T.jpg (214.07 KiB) Viewed 1711 times
This car was full of interesting improvisations like that.
jreed
Post by jreed »
Just a quick post to update on my latest adventure through the junkyard. This weekend is "50% Off" at the local yard. I couldn't believe how many people were there -- the parking lot was packed with overflow parking on the grass.
They have about 6 or so 850's there now, including two with turbo.
I got a nearly new cap, rotor and wire set (dated 2011 and in good shape), a couple IAC valves (originals from '94 and '96 from cars with ~100k miles -- may be worn out), a couple of PTC valves just in case, two Evap purge valves, speakers from the rear of a wagon, an ECC duct temperature sensor, interior cabin temperature sensors for the ECC system, an ECC control unit in really good shape from a '97 with 111k miles-- don't really need it but couldn't pass it up, and various bulbs, clips, vacuum check valves, fittings, a gas fill cap, power steering reservoir cap, a plastic arm for the recirc damper -- just in case, a fuel pump relay (marked Volvo and 2011), a hub cap cover in good shape, and a nearly new camshaft position sensor. The biggest item was a plastic splash pan that was nearly perfect. The splash pan was original Volvo and dated '96 -- amazing to see so little damage on it.
All in all a great day in the yard. Total cost: super cheap... I'm too embarrassed to mention the number. :)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Our yard had a 25% off yesterday. I had parts stashed for a just in case I had to have it. I ended up getting a few things:
1. Light blue injectors from a '01 C70, 140,000.
2. S70 cluster with 162,000, trip activated.
3. New S70 right head light assembly.
4. New S70 right front corner light.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
For our cars, those who don't do their own work, can't afford to keep 'em going or they don't make financial sense to because of age if hit with a bad trans or head gasket. The yard I frequent has a sedan that was well taken care of until??? Even the roof trims were good. some other rougher cars as well (just missed a trip computer cluster :x ) These cars are old enough to go to pick 'n pulls instead of the factory recyclers, but don't all go straight to the shredder. Get one or two "chargeable" items, and all the little stuff you can
Current Volvos:
jreed
Post by jreed »
Had a bit of extra time yesterday afternoon and I was passing near the junkyard, so I went in to see some of the 850s and S70s. I found a couple nice items including a good idle air control valve, a couple of Volvo OEM 'green' radiator caps, some side marker lights, a tan cargo net, an air pump valve controller, and a pair of key fobs for the '94-'95 850s. In the back of one of the 850s was the Volvo tool kit including the woven cotton gloves, screwdriver handle with torx, standard and phillips bits, and 10, 11, 12, 13mm wrenches.
March 2015 haul
March 2015 haul
I also saw an improvised hose clamp holding wires to the body of the positive battery terminal. Definitely not the best way to make the repair.
Found in wrecked car in junkyard: improvised wire clamp on positive battery terminal
Hose Clamp Battery Terminal.jpg (95.62 KiB) Viewed 1761 times
Has thanked: 1610 times
Been thanked: 4065 times
That's a "how NOT To" or a DDIY on that battery cable, but it did make me feel better about some of my work...
Ben850
Been thanked: 7 times
Post by Ben850 »
It's a good thing the yards I frequent are at least a half hour drive.
If they were on the way home, from anywhere, I would need another storage unit.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
jreed
Post by jreed »
Ha ha!! Yes, I agree... When I got home and went through my boxes, I found I already had two other IAC valves harvested during a previous trip, plus the original IAC that I took off of my car a few months ago, saved in case I need a component from it.
Has thanked: 2200 times
Been thanked: 1852 times
It can become addictive. Likewise it is good that the nearest pnp it 30 minutes away or my garage would be even more overloaded! Now trying to clean the garage by either testing items or learning what I need from something and scrapping, or selling it. I have multiple switches (headlight and dimmer in particular for S/V70) all of which I have cleaned and replaced the blown bulbs in. But why do I need 4 spares!
In my own defense, most of these items are cheap, and would be scrapped if not pulled, and who knows who may need them in the future when not available. We are preserving the past for the future!!
Oh, I have to go back to pnp to return the non-functioning starter, and on Wednesday this week they have a more you buy the more you save up to 40%. Oh, dear.........
You can never have too many IMHO!!
