1998 C70 T5 - Abhorrent fuel consumption/Could it be timing?
andreborges
- Year and Model: C70 T-5 1998
Thank you very, very much for the answers! I'll change the Coolant Temp sensor, as I have already bought one (because of the many reported failures). As soon as I have some reais, I'll spend in the O2 sensor, dear oragex!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
O2 sensors -- both -- are a maintenance item that should be replaced at 100,000 statute miles.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
andreborges
No perceivable improvement upon changing the front O2 sensor whatsoever. Any further ideas, guys?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
After replacing o2 sensors,maf sensor...you need to disconnect battery for at least 15 minutes in order to reset ecu & fuel trim adaptives.
After that,perform ecu re-learn procedure.You can find instructions on the forum,just search for "relearn procedure".
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
To your question on timing.
The timing on a whiteblock isn't really adjustable unless you alter the valve timing by rotating the camshaft sprocket in its slotted holes. Altering the camshaft timing really isn't recommended unless it is part of a custom ECU tune and the tuner will recommend the settings for you. From the factory the camshaft sprockets are set at the mid point on the slotted holes.
andreborges
Thanks, misha and Ozark. I performed the full relearning procedure upon replacing the sensor... No improvement.
Couldn't some mechanic in the past have messed the cam timing? Would there be any easy means of checking it?
- misha
You can check it.Remove timing belt cover,front passenger's side wheel,bend plastic shield in the wheel arch,put transmission in neutral,rotate crankshaft and check for timing marks.
Use procedure which is used for timing belt replacement,up to the removing of the belt and after installation of the belt.Forget everything in the middle of it.
Check marks on the crankshaft and on cams.If the marks are alligned that's it,if not you will need to re-allign it.
Is your ac off?
Is your ac off?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
andreborges
As for the A/C, it is blowing cold air. I believe it should, indeed, be a tad stronger, but nothing too discrepant.
villagepc
- Year and Model: 98 V70m | Stage III
- Has thanked: 3 times
- Been thanked: 2 times
Lemme tell ya a little about timing. My car's exhaust cam slipped 2 teeth and I experienced the same dramatic loss in MPG. I went from 25 / 26 mpg to about 18 /20 (i have a manual). I'd check the timing.
I'd also check for a blown out flex pipe on the exhaust system - its the braided steel hose deal that's on your downpipe from the manifold. Externally, it may appear okay - but could be collapsed internally (the liner). Now, i don't know a definitive test for this that doesn't require cutting it off - so my backwoods shade tree test may not help.
What I'm not going to tell you to do is: Go around to the back of your car while idling and see if the amount of exhaust "feels" like it should. I just place my hand over the tail pipe and feel the pressure... and if you're really a gear head, sniff your hand and check for antifreeze and for it running rich. Then wipe it behind your ears for the Eau De Volvo cologne. (kidding)
How about intake? How's the air filter? Check vacuum lines too, while you're at it. One nondescript vacuum leak can lose a few mpg's without throwing a CEL. How's the tranny fluid look ? Smelly / burnt?
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
andreborges
Intake is fine, air filter is new and the vacuum lines have all been replaced... Seems like everything points me in the timing direction!
- 4914 Views
Last post by misha
- 1123 Views
Last post by Cees Klumper
- 36 Replies
- 2403 Views
Last post by ericmci
- 36 Replies
- 14261 Views
Last post by erikv11
- 5313 Views
Last post by jimmy57
