98 S70 t5 Rough idle sputter dies often
netguyscott
Year and Model: 1998 S70 t5
Post by netguyscott »
I did use MAF spray on the old MAF, but didn't notice any changes after the cleaning, hence why I went with getting a new one. Hey last night I did discover something in my hunt to fix this. As I said before this car sat for a period of time with a cracked radiator and along with that it had an old (2004) dead battery. After removing the new battery and the battery tray below it, I found some kinda gizmo attached to the underside of the tray that had a little acid damage to its case but appears fine. However, there's a hard plastic hose that runs from it and follows under the air cleaner and its badly cracked, so would definitely be leaking. I looked up the pump-- it's labeled 1390903 and its called a vacuum booster, and is part of the Cruise control system. Could that be causing any of my rough idling problems??
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
It could-it is a vacuum line. tape over the holes in order to test it if need be, then replace if needed
Current Volvos:
netguyscott
That isn't the main vacuum pump is it? It's listed by the Volvo dealer as a part of the cruise control system, and referred to as a vacuum booster. Amazed they put a pump under the battery tray.
Has thanked: 1610 times
Been thanked: 4068 times
It's part of cruise control and could be your idle trouble. Leaking vacuum hoses will kill idle.
